Post Number: 596 Registered: 3-2007 Posted From: 71.53.155.14
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 22, 2009 - 10:03 pm: | |
Gentlemen; I have a 12kw Onan with a Perkins diesel engine and the question is::: When I fire it up the suckers smokes like a freight train and after warming up clears up and has no smoke at all and the engine was rebuilt completly and the man said that was typical of a perkins engine. How can that be? Is this normal of Perkins or what? Every thing else is OK> Gomer |
Post Number: 926 Registered: 7-2006 Posted From: 75.210.82.138
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 22, 2009 - 10:40 pm: | |
Hey, Gomer....just post NO SMOKING ZONE>..... fuel rich? Typical?...what does the Net say about 'em?...what does Onan have to say about them?...OR ...Send it to me, I'll figger it out and let you know how it goes... Best wishes............ RCB |
Post Number: 278 Registered: 11-2008 Posted From: 75.178.92.43
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 23, 2009 - 12:54 am: | |
Gomer - No worries mate. That's a quote from a guy drove boats Down Under. Said Aussies and Kiwis love the little Perkins as auxiliary engines on their sail boats. Very reliable and easy on fuel but smoke like a bas... er, freight train. Nellie Wilson |
Post Number: 575 Registered: 5-2007 Posted From: 64.40.209.13
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 23, 2009 - 6:35 am: | |
I have an older Onan DJC 12kw with Perkins, she smokes lightly at start up, then goes away quickly, 30 seconds or less. Not exactly sure on the hours, it says 1350. |
Post Number: 779 Registered: 8-2006 Posted From: 74.33.54.207
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 23, 2009 - 7:01 am: | |
Gomer, they smoke because low compression (15 to 1) and of the piston design it does not round out till the temp goes up. The 855 Cummins and the 3208 Cat use the same design. What model do you have some of the older models don't even have head gaskets just a machine fit head to block.That idea didn't last long good luck (Message edited by luvrbus on September 23, 2009) |
John Lacey (Junkman42)
Post Number: 99 Registered: 3-2007 Posted From: 66.82.162.11
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 23, 2009 - 12:21 pm: | |
Gomer, I have a perkins 4-108 in a old motor sailboat that has about 5K on the engine usually running about 1900 rpm. It has been in the boat since 1973 and has never been out of the boat. It runs fine and usually smokes for about 5 minutes and then clears up and runs clean. It will blow black smoke at 2800 rpm's. it never needs oil between changes at about 100 hours. always starts only problems are priming when losing prime in rough sea's. john |
Post Number: 1650 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 23, 2009 - 6:11 pm: | |
Unless it is pretty cold, they shouldn't do that. Something is wrong. Did it get rebored or just new rings on old pistons and honed bores? Sounds like low compression. My Perkins smokes just a little for maybe two to three seconds and then runs clean. 12KW Kohler with 2500 hours. |
Post Number: 1651 Registered: 10-2003 Posted From: 71.58.71.157
Rating:  Votes: 1 (Vote!) | Posted on Wednesday, September 23, 2009 - 6:13 pm: | |
BTW, are you using fresh fuel, or old stuff that's been in the tank for a few years. |
Post Number: 598 Registered: 3-2007 Posted From: 71.53.155.14
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 23, 2009 - 9:03 pm: | |
Chessie; the engine was completly rebuilt with rods, mains,cam, head, by a Onan dealer and the fuel is good not too old like the tank holds 30 gal and I put 10 gal in it along with stabilizer that was already in it. I think that I just need to run it until it blows LOL No after just about 10=15 minutes it will clear up pretty good. Thanks Luverbus: Not a bad idea to do that either and I will try to get the numbers tomorrow. Thanks Gomer |
clint hunter (Truthhunter)
Post Number: 513 Registered: 1-2009 Posted From: 24.129.237.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 24, 2009 - 1:41 am: | |
are the new rings broke in yet? how is the oil consumption (after break in) ? was it used at low power mostly lately and not run heavy since to clean the rings up ? ~ As long as it doesn't get worse (at the same pre-start-up tempature/humidity) after you get buring new fuel & your not trying woudering about a time limited possilbe warrenty concer, is there much to be concerned about? |
Post Number: 599 Registered: 3-2007 Posted From: 71.53.155.14
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 24, 2009 - 9:37 am: | |
Here is the specs. 12.0kw, MDJC -3CR 2268T. That unit is a marine unit if I am not mistaken. Does anyone need an owners service for a 20kw ES generator? I have one that looks brand new. Gomer |
Post Number: 1653 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 24, 2009 - 5:26 pm: | |
Since I don't know, do you know how many hours was on the unit before rebuild? Were injectors, injection pump replaced/rebuilt? Could be the stabilizer is causing it. You could try draining the fuel and replace with just fresh fuel without stabilizer to see what happens. As before, if it wasn't rebored or had liners replaced if it had them, and used old pistons with new rings, maybe the rings aren't seating very well to the reconditioned cylinder. |
