Rob Norgren (Robsedona)
Post Number: 117 Registered: 11-2007 Posted From: 75.209.128.236
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 26, 2009 - 3:47 pm: | |
Was cleaning ground block for engine on the cradle side of motor mount and saw this wire going now ware so I looked and it had a hood like a battery cable on the +battery and saw this on the water line and think did this go on this whatchamacallit
????? any one know???? don't see it in DA Book and saw nothing I could find in DA Archives! Rob |
David Lower (Dave_l)
Post Number: 229 Registered: 11-2007 Posted From: 67.58.201.14
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 26, 2009 - 8:46 pm: | |
Rob can you add a better Pic, is the wire the one in this pic that is behind the silver pipe and what is the copper pipe in the pic. Dave L (Message edited by Dave_L on September 26, 2009) |
Ralph Peters (Ralph7)
Post Number: 57 Registered: 3-2004 Posted From: 206.251.5.175
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 26, 2009 - 9:23 pm: | |
Is your starter to ground block and starter ground to engine block? You need to have a 2/0 from the frame ground/batt- to starter than starter to engine block with a # 10 or larger. |
Post Number: 930 Registered: 7-2006 Posted From: 75.218.9.112
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 26, 2009 - 11:55 pm: | |
Suggestion.....Clean the area first...then retry the pic... RCB |
Post Number: 296 Registered: 11-2008 Posted From: 75.178.92.43
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 27, 2009 - 2:04 am: | |
Wow, Rob! Clean that sucker up. Pain in the behind but amazing what you'll uncover... and sometiimes even cure. I know buddy, 'cause I've been all through that grimy, greasy, toxic process. But it pays off. Nelie Wilson |
Post Number: 1164 Registered: 12-2000 Posted From: 173.116.174.25
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 27, 2009 - 8:40 am: | |
Looks like the "fitting" directly under "Whats This" is a supplemental drin plug for the cooling system. Jack |
Post Number: 119 Registered: 11-2007 Posted From: 75.210.10.71
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 27, 2009 - 9:33 am: | |
Thanks Jack I think your Right! David yes that was the wire I found the copper pipe is the water pipe going to the solenoid valve for the old Bus heater removed now! the silver tube is for wires! Ralph the Starter and starter ground is on the other side of the bus and is #00 and starter to engine is #6 this is a pic of the drivers side The DN Alt Belt driven is just farther left in the Picture. Nelie what did you use to Clean off all the old Yuck in the hard to reach places? I Don't want to use to much presser around some of the old wires and the old presser lines. |
Post Number: 425 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 28, 2009 - 9:48 am: | |
Rob, I have used Gunk degreaser pretty succesfully but bear in mind with a detroit it's kind of a temporary thing. If they aren't leaking they aren't running  |
Post Number: 125 Registered: 11-2007 Posted From: 75.211.140.187
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 28, 2009 - 11:02 am: | |
LOL it gets cleaned and re-cleaned LOL Gunk and just a hose is what I use> Run and new stuff Yuck means its running how true :-) Rob |
hojji firemaker (Hojjifiremaker)
Registered Member Username: Hojjifiremaker
Post Number: 41 Registered: 4-2008 Posted From: 67.142.162.30
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 30, 2009 - 12:16 pm: | |
i use my 3000 psi pressure washer. It chews the old oil off in a second. Rent one if you don't have one. WAY BETTER THAN USING DEGREASER!!! be careful on your radiator fins though... It is better to clean them out from a distance or using a less focused pressure tip. My old motor is a bit of a smoker, but it sparkles... |
