Ted Gilbert (Ted01)
Registered Member Username: Ted01
Post Number: 17 Registered: 12-2007 Posted From: 71.60.34.88
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 07, 2009 - 9:22 pm: | |
compressor? Have a 6/92, bought new remanufactured compressor any tricks to know before I get started? |
Rob Norgren (Robsedona)
Post Number: 149 Registered: 11-2007 Posted From: 75.208.124.88
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 07, 2009 - 9:37 pm: | |
I think we need more Info. Compressor for AC or Air compressor for airing up the Bus. Is it the same as the old? |
Ted Gilbert (Ted01)
Post Number: 18 Registered: 12-2007 Posted From: 71.60.34.88
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 07, 2009 - 10:06 pm: | |
sorry about that Air compressor for airing up bus. and yes same as the old . old one was pushing oil. Got new gov.and guts for air dryer all from REI. |
Bob MacIsaac (Wildbob24)
Post Number: 43 Registered: 5-2007 Posted From: 67.34.62.194
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 07, 2009 - 10:27 pm: | |
Ted, Replacement is pretty straight forward. The biggest hassle is getting to it...gotta go through the floor. I'd recommend a good pressure cleaning before you lift the floor. Be sure to bleed all the pressure off the system before you disconnect the lines. You may need a gear puller to swap the drive gear from your old compressor to the new one. Once you have the mating surfaces clean, use Permatex Aviation Form-A-Gasket on both sides of the gasket before you reinstall. |
Post Number: 153 Registered: 11-2007 Posted From: 75.210.60.83
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 08, 2009 - 10:16 am: | |
Bob has it it will be straight forward A helper might be a good idea also. Do not use silicone sealer! |
