Rob A (Otto)
Registered Member Username: Otto
Post Number: 16 Registered: 12-2007 Posted From: 70.76.113.118
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 10, 2009 - 2:10 am: | |
As some of you know I have a 99 el3 in revenue service..now I have ride height troubles.. it seems the driver's side is stuck on high ride so it's a little low on the door side. does anyone know if I can do away with the e-cas system,and go back to the "old"style system of leveling valves ? getting a little tired of people with nothing better to do calling the cops saying I have a broken spring or "that bus is dangerous..it might flip over !!" so I ask the gurus here... |
Post Number: 1644 Registered: 12-2000 Posted From: 67.182.48.162
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 10, 2009 - 11:19 am: | |
Rob - Call Luke at US Coach in NJ - 1-888-262-2434. He's probably forgotten more about buses than all the combined knowledge on this board. FWIW & HTH. . .
doug yes (Dougg)
Post Number: 110 Registered: 1-2007 Posted From: 174.131.47.77
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 10, 2009 - 3:47 pm: | |
You might try Peter Pan bus in Secaucus, NJ. They maintain 100's of MCI D,J & E's, and they have done good, fast work for us. (201) 866-6001 |
Ken Barnett (Dieselbusparts)
Registered Member Username: Dieselbusparts
Post Number: 8 Registered: 7-2009 Posted From: 76.26.111.30
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 11, 2009 - 2:37 am: | |
You should be able to bypass the ECAS and install leveling valves, but why not go with the flow and just have the ECAS system diagnosed? Have you checked the air bags for cracks? Here is a link you probably already have, but just in case:http://www.meritorwabco.com/MeritorWABCO_document/tp98110a.pdf I hate working on air controls! |
Rob A (Otto)
Post Number: 17 Registered: 12-2007 Posted From: 70.76.113.118
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 11, 2009 - 3:37 am: | |
Thanks RJ and Doug...I should put those numbers on speed dial !! Ken,that is awesome...Thank ya !! |
clint hunter (Truthhunter)
Post Number: 544 Registered: 1-2009 Posted From: 24.129.237.52
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 11, 2009 - 1:32 pm: | |
if you bypass the system with non-OEM design, will it still pass your next safety inspection? -perhaps your model came with a standard system that you could convert to, likely a lot of money that might be better spent on repairing to what already exists. -- It is not safe to travel un-leveled & stressful to the frame. ---MCI has a online parts manual (a virtual bus) that might help you to look at your options; you need a account to use the parts store online site. You don't need a account to ask there tech support about OEM options, just a telephone. ...bus your cargo safely... |
