Wayne Ellenburg (Wlnburg)
Registered Member Username: Wlnburg
Post Number: 75 Registered: 6-2008 Posted From: 173.24.219.217
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 12, 2009 - 5:15 pm: | |
I have found some HT740 transmissions how do I know if they will work in an Eagle?
Post Number: 792 Registered: 8-2006 Posted From: 74.33.54.207
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 12, 2009 - 6:29 pm: | |
Wayne, that will work for you the numbers say it is for a Detroit Diesel , 2100 rpm and 7 inch oil pan. So that has the shift points and torque converter for a DD up to 450 hp Depending on the bus some 05 Eagles you need to modify the engine compartment on the drivers side not a major deal but just enough to clear takes about a hour. If you can locate a used Stone/Bennett shifter it would make life easy for you installng good luck (Message edited by luvrbus on November 12, 2009) |
Larry Baird (Airhog)
Registered Member Username: Airhog
Post Number: 174 Registered: 1-2001 Posted From: 75.209.189.226
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 13, 2009 - 12:59 am: | |
I have a just rebuilt 740 with retarders I want to sell in So Cal if your interested and it setup for a DD |
