Post Number: 388 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 12:20 pm: | |
Somthing i have disagreed with Robt the mechanic from the begining is how the air is pulled into the coach and out thru the radiator. Our set up is similar to the Flexs in that the air is pulled in thru the roof and thru the radiator past the pulling fan and out the rear of the coach. Originally this was the only air to pass thru the radiator. Now the sides of the "tunnel" are open to the upper enclosed part of the engine compartment. there was only one opening into this compartment before, a 12" round opening with louvers facing rearward on the upper corner of the drivers side. This fed (i always thought anyway) the oil bath aircleaner on the oposite of the upper compartment before the engine swap. Now the tunnel is open on both sides so air can be pulled in from the roof and from the original vent and another added on the curb side. The new dry filter pulls air from the lower engine compartment. I was in and out of the upper area last night (there are 2- 24" access cover plates in the rear bedroom "firewall") very annoyed at all the water coming inside the coach. I cant see any reason for the ram tunnel from the roof to be open on the sides to the upper compart. I will measure the opening on top and then the radiator dia. and see if that was his concern. I plan on getting the air intake turned and up into the upper compartment eventually/maybe. The thing that caught my eye last night was that the original 12" vent cover has a ssquare box on the inside and the opening is on the top and covered with fine mesh screening. This puts the opening up near the top of the compartment. Is it possible this was used to pull air out? I would say no as it used to be the only feed for this compartment to the air cleaner onthe oppisite side. Very annoyed as i should have stayed more on top of this. There is a restored unit over in Hershey that maybe i could examine and i think some of the 4103's (Dallas!) might have this same set up. Any comments or info would be appreciated. It is in the upper 60's here today with the rain tapering off, so back to fixing the found leaks and measuring. I also found some original stencils in the rear compartment GM TRK & COA DIV CHICAGO ILL. I will take a picture later and try and post picts that show what i am rambling about. ULTCN. I tried posting a pic but the file is to large. |
Patrick levenson (Zubzub)
Post Number: 122 Registered: 5-2007 Posted From: 174.91.226.239
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 12:34 pm: | |
No idea what you are talking about as I have a modern coach but I'm pretty sure you can use a IMG link from photobucket here much easier than resizing and also gives you a place to store pics away from your computer. 'll try a link to see [IMG]http://i392.photobucket.com/albums/pp3/zubzub_photos/IMG_1022_3.jpg[/IMG] '53 4014 (Message edited by zubzub on November 15, 2009) (Message edited by zubzub on November 15, 2009) |
Post Number: 123 Registered: 5-2007 Posted From: 174.91.226.239
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 12:49 pm: | |
weird the first time I tried it it worked as a clickable link but when i edited the post it turned into a copy and paste kind of link. should be like this [IMG]http://i392.photobucket.com/albums/pp3/zubzub_photos/IMG_1022_3.jpg[/IMG] |
Brandon Merritt (Brando4905)
Registered Member Username: Brando4905
Post Number: 21 Registered: 3-2009 Posted From: 173.69.70.103
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 3:33 pm: | |
Zub, Is that a Vanagon toad? Nice! Sweet looking bus too! Brandon |
Dallas Farnworth (Dallas)
Post Number: 6 Registered: 7-2004 Posted From: 75.88.10.199
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 5:30 pm: | |
Sorry David, The 4102's and 4103's had the air take for the air cleaners in the top edge of the D windows on the side. The 4101's might have been different since they had the target sign on the back like the 4151 and 3751. The radiator on the 02's and 03's was the same as the 4104 on up. I'll look around and see if I have the parts drawings of the older buses, maybe you could get some idea from that. Dallas |
Post Number: 124 Registered: 5-2007 Posted From: 174.91.226.239
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 8:54 pm: | |
wow sharp eyes...didn't even notice my toad in the pic...it's a eurovan. more pics of my bus and stuff at http://s392.photobucket.com/albums/pp3/zubzub_photos/ |
Post Number: 389 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 9:21 pm: | |
Thanks Dallas and Patrick i will check out the resizing after some supper. After being in and out and on the roof i know why Robert wanted more air to be available to be pulled thru the radiator. The original radiator was mounted higher and sloping rearward almost 45 degrees. Now it is almost straight up and down and the expansion tank is blocking a third of the upper intake area. I think i will block off the side areas and take her out for a run since we are having a heat wave here! When i picked her up in Aug we had slow rising temps when hill climbing and again in Sept towing the jeep in Pa in the hills. It is going to be a major pain to lean the radiator back. I would think (notice i am never saying assume! ha ha) with the radiator straight up and down there could be air flow issues meaning most of the air would be pulled in thru the top of the radiator instead of thru the whole rad top to bottom. Real scientific WAGuessing here! (Nellie, thats a WAG= wild ass guess) I am pretty sure i can make the run down to Florida towing the bikes with out any overheating problems and maybe if i get the trans cooler out of the engine cooling loop this wont matter anyway. That will have to wait for spring and i want to see some other rigs in Arcadia and how they cool their transmissions. Just throwing it up in the air. Thanks for any insight. And since i cant get anyone to BITE on the last couple of posts with ULTCN i give up. Nellie i am so dissapointed. |
Post Number: 8 Registered: 7-2004 Posted From: 75.88.10.199
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 10:15 pm: | |
David, does the radiator have a shroud? If not, build one to fit as tight to the fan as practicable. Also, do you have the full length flap across the back behind the drive tires? It will really help move the air through the engine compartment by creating a low pressure area and causing fresh air to be sucked in. |
Post Number: 390 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 10:27 pm: | |
Ok, Patrick i found and read the photo buket site and can load a couple of pics but how do i post them here? Trust me, it took forever and someboady else to post my avitar photo. Thanks dave |
Post Number: 391 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 15, 2009 - 10:33 pm: | |
Thanks Dallas, yes it does have a shroud and no it dosent have a flap. You able to make it to Jacks this year? |
Post Number: 125 Registered: 5-2007 Posted From: 174.91.226.239
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 16, 2009 - 3:06 am: | |
Once you have pics on photobucket click on the pic you want. when the pic comes up you will notice a black and white bocx on the left called Share This Image. the bottom line of text there starts with IMG you need to copy paste that from there to your post and then we can click and see it |
Post Number: 597 Registered: 5-2007 Posted From: 64.40.209.25
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 16, 2009 - 4:58 am: | |
I made this short video on posting pictures using Photobucket, although some information you can't use here, it might help. This board is kind of difficult for posting pics, I gave up long ago. Too much code to deal with and instructions to follow. http://www.youtube.com/watch?v=xALiEFIzCL4 (Message edited by dreamscape on November 16, 2009) |
Post Number: 9 Registered: 7-2004 Posted From: 75.88.10.199
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 16, 2009 - 9:15 am: | |
Nope, we won't make it to Jack's this year, we'll be managing a campground in our little piece of heaven..... Texas! If you get out on the road and don't have anything to do, stop by for a cup of coffee or a BBQ |
Post Number: 392 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 16, 2009 - 10:06 pm: | |
[IMG]http://i954.photobucket.com/albums/ae24/dezeldave/dinahmoe2009009.jpg[/IMG] well here goes ! |
Post Number: 393 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 16, 2009 - 10:22 pm: | |
[IMG]http://i954.photobucket.com/albums/ae24/dezeldave/dinahmoe2009028.jpg[/IMG] Yahoo! thanks Paul and Patrick. Dallas i am bummed you cant be there but i really understand. texas Bar b q! have to check that out. So back to the post! The radiator is in the upper section. the original vent is upper left. Another matching one has been added other side. The upper compartment is from the silver portion upwards. that is the dividing point of the engine compartment.If i ge |
macgyver (91flyer)
Post Number: 552 Registered: 11-2004 Posted From: 74.193.188.165
Rating:  Votes: 1 (Vote!) | Posted on Tuesday, November 17, 2009 - 9:52 am: | |
You said yours is similar to how a FLX works... Here's what I found on the FLX Owner's Group site...
From the site Flxible Owner's Group:
quote:There is one popular bodge with which some owners report success. Since the belly pan is usually missing, and usually awkward to duplicate, some owners have elected to build an "air dam" - a full-width mudflap behind the rear wheels.This mudflap is mounted at the bottom of a full baffle designed to prevent airflow from floor to mudflap. Thus the rearward underbus airflow is directed to the sides, hopefully even aiding in the creation of a low-pressure area behind it, which will help the proper flow through the scoop, above-engine duct, and fan/shroud.
Post Number: 394 Registered: 10-2004 Posted From: 173.77.211.93
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 17, 2009 - 10:40 pm: | |
Nice picture Mac, congrats on the new bus! Our GM just sent the air staight out the back after pulling thru the rad.Now i am second guessing my memory and will pull what i can from the parts service book and see what is what. The one in Hershey will soon get i visit i think. |
