Darrell Black, DVM (Darrelldvm)
Registered Member Username: Darrelldvm
Post Number: 52 Registered: 6-2005 Posted From: 72.4.181.208
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 13, 2010 - 10:53 pm: | |
I have an Onan 8k diesel in the old air conditioning bay on my '06. I am have an 8"x28"x2.5" oval muffler under the bus running to exit in front of the rear tire. It has been hit on the ground too many times, I need a new one. Question: What kind of muffler are you using for your gen set? And where do you get it? DArrell |
Post Number: 1067 Registered: 11-2005 Posted From: 208.54.196.244
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 13, 2010 - 11:03 pm: | |
I would get a very small, straight through, round muffler from JC Whitney where I get all my exhaust stuff because they have such a good selection at reasonable prices. Some of their round mufflers are very rugged. For such a long exhaust and small engine you won't need much of a muffler. You might even try it with no muffler to see what happens. Is there any way you can install the muffler before it goes under the bus? Mine exits out the side, our AC compartments are in the same location. Even better is a side exit with a vertical, detachable pipe for when parked. |
Bill Gerrie (Bill_gerrie)
Post Number: 344 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 13, 2010 - 11:17 pm: | |
Darrell I used a muffler from an older Honda car. Cheap and it was oval so it didn't stick down too far. Bill |
Post Number: 1040 Registered: 7-2006 Posted From: 74.235.211.242
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 13, 2010 - 11:25 pm: | |
Give Pete/Daytona a yell. He's either here, or on that "other" board. He had showed me a muffler that makes the thing silent, but I forgot what the hell it was. Here: http://www.busnut.com/cgi-bin/bbs/board-profile.cgi?action=view_profile&profile=pete_rtsdaytona-users (Message edited by john_mc9 on January 13, 2010) |
Van (Van)
Registered Member Username: Van
Post Number: 102 Registered: 7-2008 Posted From: 68.108.81.25
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 14, 2010 - 1:05 am: | |
A few 90 degree bends in some straight pipe seems to quiet them down quite a bit. |
Post Number: 591 Registered: 1-2005 Posted From: 97.104.18.110
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 14, 2010 - 7:36 am: | |
John MC9 I think you may have me confused with someone who knows what he's doing. ?? I have a 7KW Onam emerald gas genny - it has an internal muffler - I just pipe it thru a removable aluminum downspout when using the genny at rallies |
Post Number: 1041 Registered: 7-2006 Posted From: 74.235.211.242
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 14, 2010 - 10:21 am: | |
Naww Pete... You told me about an automotive muffler for the Honda liquid cooled 6010 I bought from youse awhile back.. I still have the genset, and never got the muffler.. and the bus is gone, along with my brain.. can't remember the muffler brand/type, and was hoping you could. I thought you had said you used one and it was the best one to use. (I'm not crazy, I swear!) ( I've been swearing for years) |
Post Number: 1072 Registered: 7-2006 Posted From: 75.208.28.180
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 14, 2010 - 10:31 am: | |
Good to see you back, JTNG...been thinkin' about you! Stop swearing,...it's not good for the air... RCB |
Post Number: 1042 Registered: 7-2006 Posted From: 74.235.211.242
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 14, 2010 - 2:03 pm: | |
Hey Chuckie! I've been around, but just layin' low... It's no fun around here anymore with the engineers and code gestapo gone. I guess they're all over that "Butt Book" thing, ehh? HAR HAR Oh well... Maybe I'll make Old Man I@n jump around again, just for the halibut. Later, dude... gotta take a nap... |
Post Number: 1834 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 14, 2010 - 4:51 pm: | |
I think that NAPA still lists chambered pipe in their exhaust catalog. It is only about 2 1/2 inch in diameter. If the muffler you currently use is only 2 1/2 in dia, are your leveling valves set properly? Or you going over very uneven surfaces? I have one similar (4 inches high) under the 04 and don't have a problem. |
Tom Christman (Tchristman)
Post Number: 170 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 15, 2010 - 11:45 am: | |
Highly recommend you get a Diesel rated muffler like from Donaldson. While a car muffler may work for awhile, the holes in the baffles on a car muffler are typically too small to pass the carbon build up from a Diesel genset, hence in a few years they get clogged up and make for more back pressure. The Diesel rated muffler has bigger baffle holes that will allow the soot to pass. Good Luck, TomC |
Post Number: 1069 Registered: 11-2005 Posted From: 173.202.2.221
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 15, 2010 - 6:15 pm: | |
If he uses a straight through packed muffler he won't have any hole problem. |
