Mark Renner (Boomer)
Post Number: 189 Registered: 11-2006 Posted From: 75.243.105.150
![](http://www.busnut.com/bbs/messages/thumbnails/20197.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 12, 2010 - 8:59 pm: | |
I am looking at a '47 PD3751. Very, very straight body and tin work with original lighting, and even original A/C and motor still in. Desert car with little rust or corrosion. What were the bad points with them? Did they have bulkhead cracking issues? Any fan issues? It has an Air-o-Matic steering assist conversion. Any input would be appreciated. Thanks. |
Post Number: 1084 Registered: 11-2005 Posted From: 173.202.45.50
![](http://www.busnut.com/bbs/messages/thumbnails/17271.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 12, 2010 - 9:43 pm: | |
Tim Hoskinson is the guy you want to contact, he owns 2-3 3751/4151s. Don't know for sure if he is on this board but he is for sure on the other one. |
Post Number: 425 Registered: 10-2004 Posted From: 173.68.141.245
![](http://www.busnut.com/bbs/messages/thumbnails/14850.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 12, 2010 - 10:39 pm: | |
2 or 3? i would double that amount! Tim is the man. He will answer any of your questions. Careful tho, he talked us into getting one! he will probably see your post shortly. Tim told me that you should check the rivet roof line at the rear door. Steering and kingpins as the front axle is hard to find one in good shape. Make sure the shift linkage is tight. The best thing is that these buses were built to be repaired. Most everything can be taken apart and repaired. Try to find out what rear end ratio it has as the top speed on todays hiways can be an issue. good luck they can be a great bus |
Tim Hoskinson (Tdh37514151)
Post Number: 257 Registered: 9-2004 Posted From: 65.25.139.50
![](http://www.busnut.com/bbs/messages/thumbnails/7194.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 12:29 am: | |
Hi Mark a Silverside is always a fun adventure and to me one of the best looking buses ever built. I have at this point six Silversides all 1948. I am not much for typing but you are welcome to e mail me the e mail address is in my profile. I will get back with you and send you my phone number. I am always available to talk Silversides. Tim |
Post Number: 1079 Registered: 10-2006 Posted From: 66.82.9.62
![](http://www.busnut.com/bbs/messages/thumbnails/19648.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 6:40 am: | |
It has an Air-o-Matic steering assist conversion. Air o Matic is still in business so if parts should ever be needed , no problem. Many folks prefer the AoM to fulltime power steering as it can be shut off 95% of the time and the bus will wander less on the highway. The downside is the gearing is not stepped up ,(as on a full time power box) so in parking in an RV place it will be more (but easy ) turns lock to lock . Be sure to get DA Book, and since its been in a desert sand land , grease everything TWICE , at least. Good Luck FF |
Bestekustoms (Mrbreeze)
Registered Member Username: Mrbreeze
Post Number: 21 Registered: 12-2009 Posted From: 174.16.109.152
![](http://www.busnut.com/bbs/messages/thumbnails/32813.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 11:02 am: | |
Now... I Know How Clifford Knew.!!!! I Started Thinking Maybe, Just Maybe... He Does Know Everything..LOL !! John |
Post Number: 1085 Registered: 11-2005 Posted From: 173.202.36.183
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 6:35 pm: | |
Tim once told me to look for cracking in the body above the rear wheel well. The telltale was cracking below the window above the rear wheel. There was a GM fix for that which was a huge steel strap bolted fore and aft above the axle. The really neat things are the art deco rear end and the steering column shifter! Also, no air bags to worry about. I tried very hard to find one but they are not numerous in good condition. (Message edited by gusc on February 13, 2010) |
Post Number: 258 Registered: 9-2004 Posted From: 65.25.139.50
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 16, 2010 - 12:01 pm: | |
Mark I didn't here from you. Did you buy the Silverside? Tim |
Post Number: 195 Registered: 11-2006 Posted From: 201.143.23.83
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 19, 2010 - 3:32 pm: | |
Hey Tim, yes I did get it. We are in Mexico for a week, then going back up to retrieve and ship it. I will have a ton of questions for you. Hope you are patient. All manuals came with it. |
Post Number: 259 Registered: 9-2004 Posted From: 65.25.139.50
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 19, 2010 - 10:03 pm: | |
I am always glad to talk about silversides. Feel free to contact me when you get your bus and we will go over some things. Best of luck. Tim |
