Douglas Wotring (Tekebird)
Post Number: 421 Registered: 10-2004 Posted From: 71.57.224.23
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 5:03 pm: | |
what do you suppose the max air pressure an MCI Air tank will take found a new tank 25"x 7.5" which I think would fit nicely under my enclosed motorcycle trailer for "shop air" when away from home/the coach |
Patrick levenson (Zubzub)
Post Number: 151 Registered: 5-2007 Posted From: 174.91.229.84
![](http://www.busnut.com/bbs/messages/thumbnails/25135.jpg)
Rating: ![](http://www.busnut.com/bbs/icons/s100000000.gif) Votes: 1 (Vote!) | Posted on Saturday, February 13, 2010 - 5:16 pm: | |
Most truck air systems have safety valve pop offs set between 125 PSI and 225 (that's what the aftermarket pop offs adjust to). Given that most air lines are rated for 250 while usually carrying 125, I would guess an MCI tank would have no trouble with 125-150. If you want to supercharge it (250) for more reserve you might get in trouble. Just guessing here, all pure conjecture and a bad cold talking. |
Post Number: 1801 Registered: 12-2000 Posted From: 76.71.100.208
![](http://www.busnut.com/bbs/messages/thumbnails/14343.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 15, 2010 - 11:03 am: | |
How high can your shop compressor pump? The attachments will rupture long before the tank will. Somewhere in the dark recesses of my head, 300 lbs is bobbing in the flotsam? You'd need to ask a tank manufacturer, or perhaps a Bendix rep, the coach folks won't know. happy coaching! buswarrior |
Post Number: 152 Registered: 5-2007 Posted From: 174.91.229.84
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 15, 2010 - 11:40 am: | |
Oh yeah I just remembered that scuba tanks are the way to go for high pressure. |
Dale Waller (Happycampersrus)
Post Number: 369 Registered: 7-2005 Posted From: 166.225.52.152
Rating: ![](http://www.busnut.com/bbs/icons/s111111111.gif) Votes: 1 (Vote!) | Posted on Monday, February 15, 2010 - 2:46 pm: | |
I drag race motorcycles on the weekends and use nitrogen for tires and air shifter. Go to a welding supply and get a "90" bottle (scuba tank size)and a regulator. They are charged to 2500lbs or so and last a long time. Tank refills are around $20 bucks |
Post Number: 1802 Registered: 12-2000 Posted From: 76.68.133.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 16, 2010 - 9:06 am: | |
BBQ tanks are another source for a poor man's air pig. happy coaching! buswarrior |
