Cory hart (Chart1)
Post Number: 3 Registered: 1-2010 Posted From: 64.16.170.170
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 6:33 pm: | |
I am going to plate the airbags on my mci. My question is due to rusting of the airframe, would it be possible to spray a rust inhibiting paint inside the air frame before blocking it of to prevent further rusting from the inside? |
Roger Dalke (Roger_d)
Registered Member Username: Roger_d
Post Number: 27 Registered: 8-2007 Posted From: 205.206.150.211
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 8:39 pm: | |
All the rust to the airbeams on my MC7 was from the outside in. When I cut them open, they looked like brand new inside.(not even painted from the factory) The rust was from salt and road grime sitting on top of the beams. I am just planning to be meticulous about cleaning the undercarriage, and have used a good quality rust paint on the outside(por-15) |
Cory hart (Chart1)
Post Number: 5 Registered: 1-2010 Posted From: 64.16.170.170
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 13, 2010 - 8:59 pm: | |
Roger thanks , I haven't had a chance to see inside. I just thought they would rust from the inside also from moisture in the air lines. I am planning on spraying the whole underside with a preventive paint. |
Post Number: 1088 Registered: 11-2005 Posted From: 173.202.15.158
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 14, 2010 - 7:15 pm: | |
Something like LPS-3 or Corrosion X will work fine, just fog and close. Even the cheaper ones you buy in WM will probably work fine. |
