Vern Rainville (Vern_in_ri)
Registered Member Username: Vern_in_ri
Post Number: 11 Registered: 1-2010 Posted From: 68.230.145.126
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 22, 2010 - 6:19 am: | |
Does anyone know where to find a bus cover? 45' X 102" X about 12' high. Tyvek or something inexpensive as I will only use it for about a year and be done with it. Vern |
Tim (Timkar)
Registered Member Username: Timkar
Post Number: 133 Registered: 10-2004 Posted From: 64.141.73.7
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 22, 2010 - 10:47 am: | |
When I got one for my S&S these guys were about the best deal around. Not quite sure if they'll work for you but HTH. Tim http://www.coversuperstore.com/ |
Iver (Mciv)
Registered Member Username: Mciv
Post Number: 29 Registered: 11-2006 Posted From: 70.69.131.252
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 23, 2010 - 2:46 am: | |
Use caution when covering your coach. Most fabrics can be abrasive and might damage your paint job. If you do decide to use a cover it is very important that the material is breathable and try to keep an air space between the coach and the fabric. A shelter works better. Maybe you could use one and then sell it when you're done with it. HTH, Iver. |
Post Number: 12 Registered: 1-2010 Posted From: 68.230.145.126
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 23, 2010 - 5:29 am: | |
Hi Iver, Thanx for the imput ! My choice would be a "Tyvek" cover. Light & breathable. Fabric sounds good, but an air space would be hard to maintain, since I will be using the coach every 3-4 weeks. I am open to suggestions though. Portable shelters will not work for me as I do not have much land. This will be a temporary solution until my other (project) Eagle is sold. Then I will be able to store indoors. Vern |
gary throneberry (Garhawk)
Registered Member Username: Garhawk
Post Number: 31 Registered: 3-2007 Posted From: 68.119.106.206
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 23, 2010 - 9:38 am: | |
Hi Vern, For two years now, I have owned a cover made by: Calmark Custom Covers, phone eight 0 5 486 3863. It covers our '78 GMC Motorhome which is 26' in length and, made of fiberglass and aluminum. The material has not scarred the finish at all and, breathes exceptionally well. We are very pleased with the cover and recommend it highly. I believe the cost is in the $400 range although, we were fortunate to find this one at a GMC rally for somewhat less. When necessary, I can install the cover by my lonesome but, more hands are better. One note of caution: insure the zipped door installation matches your coach. |
George M. Todd (George_todd)
Post Number: 947 Registered: 8-2006 Posted From: 99.39.13.50
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 23, 2010 - 8:08 pm: | |
The whole purpose of Tyvek is to stop air circulation in and out of house walls. The various brands of infiltration barrier are the main reason for the amount of mold problems in newer homes. No air circulates inside the walls anymore, so once they get wet, they never dry out. G |
mike smola (Mikke60)
Registered Member Username: Mikke60
Post Number: 1 Registered: 1-2010 Posted From: 24.61.3.16
Rating:  Votes: 2 (Vote!) | Posted on Tuesday, February 23, 2010 - 9:07 pm: | |
Not true. Tyvek and similar products are designed to breathe. Though they do keep air from infiltrating inward ,they do allow moiture to escape. Mike |
Post Number: 1101 Registered: 11-2005 Posted From: 173.202.43.134
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 23, 2010 - 9:51 pm: | |
If you use a non breathing cover and park in the sun and have moisture under the cover I can guarantee some nice paint blisters on top of the bus. |
