Post Number: 510 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 26, 2010 - 10:11 am: | |
Hello busnuts, Is there a particular grease you guys use when hitting the zirc fittings on the suspension and slack adjusters? |
Post Number: 850 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 26, 2010 - 1:37 pm: | |
Synthetic grease is the best because it doesn't dry out and repells water and lubs better! gomer |
Post Number: 1133 Registered: 11-2005 Posted From: 173.202.22.55
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 26, 2010 - 6:41 pm: | |
Grease is grease. Today even bearing and chassis grease are often one and the same. Took me a while to accept that one! The parts you mentioned use plain ole chassis grease as recommended in most bus manuals. The little bit most of us use our buses probably doesn't call for anything exotic. |
David Guglielmetti (Daveg)
Post Number: 156 Registered: 2-2009 Posted From: 66.122.182.221
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 26, 2010 - 7:31 pm: | |
Any grease is better than no grease. Chassis lube is generally NLGI #2, while I prefer a #1 for auto-slacks...again, we all have our preferences but I would cautiously say that grease is not as critical as oil with regards to old buses and two-stroke engines. |
Bill Holstein (Billmoocow)
Post Number: 60 Registered: 5-2009 Posted From: 98.232.207.25
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 27, 2010 - 2:08 am: | |
I think they would be happy with just about anything if you where to give them attention. Probably something that should be more pampered but is not. |
Post Number: 511 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 27, 2010 - 3:08 pm: | |
Thanks guys. I had a hard time acepting wheel bearing and chasis could be the same thing as well. I remember certain applications in the past needed something with moly in it and didn't know if there were any special requirements for our HD equipment |
Patrick levenson (Zubzub)
Post Number: 197 Registered: 5-2007 Posted From: 174.91.225.235
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 27, 2010 - 7:02 pm: | |
I like the red/pink synthetic. It's pretty. Doesn't really cost much more than the regular stuff if you are buying by the tube. And it's Prettier! |
Post Number: 851 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 27, 2010 - 10:24 pm: | |
I tried to post awhile ago and I lost my network so I will say it again. Synthetic is a little more in price than petroleum grease but it is more stickable[LOL]than it is also. It is water resistance and will stay in place long after pet grease has gone. I just use it wherever I need grease and try to wash it off with soap, It ain't gonna happen it will take thinner,gas or somthing like that. I am not selling AmzOil product however I use them exclusive whenever I can,not in the DD engine tho. I use it in my cars and trucks tho. Not Mobile 1 Or anyother synthetic,Just AmzOil Period!! It may cost more but the results are far worth the extra money. My thought only and I don't want to offend ANYONE with this post!! Gomer |
George Martinez (Foohorse)
Post Number: 58 Registered: 1-2010 Posted From: 76.109.100.30
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 27, 2010 - 11:39 pm: | |
myself I like the pretty red grease as well. but the blue marine stuff is hard to resist, it also is very pretty. |
Post Number: 198 Registered: 5-2007 Posted From: 174.91.225.235
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 2:39 am: | |
Oooh Blue!! I hadn't seen the blue. That will go perfectly with my undercarriage. |
Post Number: 1836 Registered: 12-2000 Posted From: 76.66.17.117
Rating:  Votes: 1 (Vote!) | Posted on Sunday, March 28, 2010 - 8:18 am: | |
I like a grease with some colour in it, so I can tell when it is making it out the other side in applications where that happens, yokes, farm tractor, sleeves, etc. the colour quickly fades once in use, so you can tell when the older lube has been pushed out. My current choice is a Valvoline product called Cerulean, largely for the convenience; I buy the tubes by the case at the local farm supply. Besides the suggestion that any grease is better than no grease, I would also recommend a powered grease gun: He who gets tired squeezing, tends to squeeze less... There's a lot of fittings and a lot of contortions to reach them all. It is far too easy to lose one's zeal for excellence in preventive maintenance once the body is complaining! happy coaching! buswarrior |
Post Number: 438 Registered: 10-2004 Posted From: 173.77.207.138
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 11:16 am: | |
and a small flex hose with a tight fitting adpt on the end. Sometimes a flex helps sometimes you need the hard push of a solid end to get her to take. I love laying under the bus once in a while and checking everthing out while hitting the grease lever. We lost the great multi port fitting bank to the shift linkage during the repower and now i am not as anxious to crawl under with air bags in the rear. as 4 the colors, we have the marine blue now as opposed to the old black then green. Looking foward to getting some red, is this a red/blue state issue? And whats the deal with the powered unit? Drag a air hose with you or is it like the battery powered caulk guns? |
Post Number: 1135 Registered: 11-2005 Posted From: 173.202.36.75
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 11:57 am: | |
I may never be happy with black or dark green grease again after reading about this pretty grease! |
Tom Christman (Tchristman)
Post Number: 200 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 12:26 pm: | |
Whatever grease says heavy duty high pressure is what you want. Good Luck, TomC |
Post Number: 1837 Registered: 12-2000 Posted From: 76.66.17.117
Rating:  Votes: 1 (Vote!) | Posted on Sunday, March 28, 2010 - 12:58 pm: | |
There are old school airline powered grease guns, and new fangled rechargeable battery powered ones. for example: http://www.lincolnindustrial.com/asp/products/powlub.asp I echo the convenience of a good length of flex hose on your grease gun. Fittings that resist taking on grease should be investigated closely for possible replacement or for blockage. happy coaching! buswarrior |
Post Number: 59 Registered: 1-2010 Posted From: 76.109.100.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 1:34 pm: | |
Patrick! there's GREEN also!! if it's British racing green I may wet myself with excitement |
Dallas Farnworth (Dallas)
Post Number: 34 Registered: 7-2004 Posted From: 72.172.43.196
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 4:41 pm: | |
Are you forgetting about the pretty purple with the awesome gold/silver flecks in it from Mystic? |
Post Number: 1188 Registered: 7-2006 Posted From: 75.245.156.180
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 28, 2010 - 10:19 pm: | |
RCB |
Post Number: 60 Registered: 1-2010 Posted From: 76.26.21.45
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 29, 2010 - 6:02 pm: | |
AAARRRHHHGG oh boy. must go change... uh never mind. purple with glitter. this must be recommended to the owners of the motor home that was walled with mirrors and lights only thing missing was the pole. thread.. Some Photos for Ideas and Inspiration. LOL |
Justin Burie (Justinb)
Registered Member Username: Justinb
Post Number: 16 Registered: 1-2010 Posted From: 209.254.23.194
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 30, 2010 - 12:54 pm: | |
[quote="GeorgeMartinez"] ---------------------------------------------- .....there's GREEN also!! if it's British racing green I may wet myself with excitement ----------------------------------------------- Just stay away from their electronics. From the vintage road racers: Lucas Electronics = The Prince of Darkness |
Post Number: 1140 Registered: 11-2005 Posted From: 173.202.9.56
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 30, 2010 - 9:16 pm: | |
I'm a Brit fan too but my two are bright red and mulberry!! |
Post Number: 62 Registered: 1-2010 Posted From: 76.109.96.202
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 30, 2010 - 10:39 pm: | |
and the lord of room temperature ale, Lucas for a time made refrigerators as well. yes that's good advice Justin although the resulting electrocution may wake the monster more than the blue pill crap. [quote= Dr Frank N Stein] IT'S ALIVE!! AH HA HA HA HA!......uh sorry Tim this threads gone way way south. It's all Patrick's fault |
Post Number: 514 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 31, 2010 - 9:44 am: | |
No worries George. I have some old Brit iron as well. When it comes to Lucas you just need the correct tools. http://members.tccoa.com/timb/LucasTool.jpg |
John Lacey (Junkman42)
Post Number: 115 Registered: 3-2007 Posted From: 69.19.14.31
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 31, 2010 - 4:40 pm: | |
Tim, can I assume that You never rode brit bikes back in the fifty's? The only tools I ever thought about would need fuses and matches to correct Joe Lucas problems. I never trusted anything lucas out of sight of street Lights. YMMV John L |
Post Number: 515 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 31, 2010 - 5:11 pm: | |
You would be correct John. I have mostly driven BMW twins. I currently have a 68 Jaguar Etype and you are correct I don't venture out too far after dark  |
Post Number: 37 Registered: 7-2004 Posted From: 72.172.43.196
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 31, 2010 - 10:35 pm: | |
What about those wonderful Girlig brakes on the UK cars? Our method was, if it works, there's something wrong... change it! |
Post Number: 116 Registered: 3-2007 Posted From: 69.19.14.31
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 01, 2010 - 8:47 am: | |
Dallas, I always wondered why cars made in a country where there is hardly ever a dry day manufactured cars that leak when it is not even raining! By the way I must admit My father was born in 1912 in the UK, and a lot of My family lives in Canada. I had also a 2+2 v12 etype and I gave up keeping the alternator and ignition system working and did I mention the $250 dollar head gaskets? But when the beast ran it really ran! I loved all of My Brit cars but I loved some of the women no longer in My life! Makes no sense I know. John L |
Post Number: 516 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 01, 2010 - 9:15 am: | |
John, I understand that as well....thus why my 2+2 has a GM 1 wire alternator retrofitted. On the plus side you don't have to worry about corrosion on the undercariage with the oil leaks |
Post Number: 549 Registered: 9-2004 Posted From: 65.23.106.193
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 01, 2010 - 11:13 am: | |
On my XJ12L, the 4 carbs leak enough gas to wash off all that oil . . . . No, I don't drive it much, at less than 10 mpg & less than 20 gallons in the tanks, it requires so many stops for gas, it is almost faster to walk. It is a nice ride tho . . . |
Post Number: 517 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 01, 2010 - 11:59 am: | |
I find it kind of interesting that the busnut sickness that afflicts us all seems to have other common vehicular side effects. As if busses aren't enough of a headache from time to time we need british autos to tinker with |
Post Number: 550 Registered: 9-2004 Posted From: 65.23.106.193
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 01, 2010 - 1:17 pm: | |
If you own a dog, you may as well own a cat too. |
Post Number: 63 Registered: 1-2010 Posted From: 174.48.4.129
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 01, 2010 - 6:49 pm: | |
Tim I believe that the sickness you are referring to is masochism. But in defense of Mother England and the fine craftsman there. My 1961 Rolls Royce Silver Cloud II has been without a doubt the most trouble free car I have ever owned Asian products included. huge appetite for fuel, but a great car nonetheless. I miss her |
