thomas flocks (Taflocks)
Post Number: 231 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 17, 2010 - 3:30 pm: | |
i bought a tank-less propane water heater on e-bay for $52 brand new my question is how do i vent it? i want to put it on a divider wall in a lower bay. i was thinking of venting it out to a hole in the door with a furnace exhaust cover on the door so when the door closes the pipe would go right through the hole. any better ideas? |
Post Number: 353 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 17, 2010 - 4:00 pm: | |
If you don't already have them, I would go to the manufacturers website and get their installation instructions and follow them very carefully. Remember that you must also provide air to the unit as well as exhaust the fumes. |
Post Number: 232 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 17, 2010 - 7:44 pm: | |
not to worried about air as my seals in the bay are rather drafty.... also the manufacturer doesn't seem to have a website? |
George M. Todd (George_todd)
Post Number: 992 Registered: 8-2006 Posted From: 99.68.225.138
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 17, 2010 - 10:10 pm: | |
Tom, Please look at the thread "Water Heater," about 8 posts down. Then tell us the BTU rating of yours, and anything more that you can. Then we'll try to help. G |
Post Number: 233 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 17, 2010 - 11:00 pm: | |
http://www.ioffer.com/i/NEW-GAS-TANKLESS-WATER-HEATER-SYSTEM-LPG-SAVE-7092027 (Message edited by taflocks on April 17, 2010) |
Post Number: 1158 Registered: 11-2005 Posted From: 173.202.8.206
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 18, 2010 - 12:14 am: | |
Tankless water heaters use a tremendous amount of LP and put out a tremendous amount of heat compared to tank heaters. You will need a lot of vent capacity. I was going to install one in my house but my LP line from my tank is too small (3/8", Min size is 1/2"). This gives you an idea of the heat involved. |
Post Number: 354 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 18, 2010 - 9:55 am: | |
I have a tankless water heater at home and we are very pleased with it. However, it is 140,000 BTU, natural gas and we are in Florida where the incoming water is close to 70 degrees all the time. Frankly, I would not consider any of those noname imports for my house or bus. If I were to go tankless it would be Bosch, Rheem, Noritz (the one I have) or Rinnai. Also, if it is not AGA and UL approved, I would not consider it. |
Post Number: 1275 Registered: 12-2000 Posted From: 173.150.182.227
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 18, 2010 - 10:36 am: | |
I heard that tankless units are rated in degrees that the water temp is increased as the water flows through the unit. Since most residential water comes out of pipes buried in the ground, the water is usually around 65-70 degrees when entering the unit. A 35 degree increase would give you 100-105 shower water. In an RV camped in a cold area without bay heat could easily put 40-45 degree water into the unit, add 35 degrees and you have 75-80 degree water. I do not like cold showers! I would suggest checking the rating and see what the rated temperature increase is and consider the coldest expected water temp entering the unit based on where and how you use your unit. Jack (Message edited by JackConrad on April 18, 2010) |
