thomas flocks (Taflocks)
Post Number: 235 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 5:28 am: | |
it seems they only make 3.5 inch pipe in china and not the usa, i have tried all the stores and no way to get pipe.also when installing it i didn't use their fittings but decided to use better pex fittings,well i snapped the cold water fitting right off.but that was a plus as i was able to just slip a piece of rubber hose over the cold side and on to the T that i made.i now have to remove the T'S from the tanked water heater that is under the sink.i will try some 3 inch pipe that i will expand with a muffler expander for the exhaust. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320514209970&ssPageName=ADME:X:RTQ:US:1 123 |
Post Number: 1236 Registered: 7-2006 Posted From: 75.244.110.80
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 10:47 am: | |
You should be able to find a reducer...save lots of headaches...maybe> RCB |
Post Number: 1279 Registered: 12-2000 Posted From: 67.142.168.139
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 12:01 pm: | |
3" to 3.5" is a lot of expanding. Jack |
John Lacey (Junkman42)
Post Number: 118 Registered: 3-2007 Posted From: 66.82.9.11
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 12:26 pm: | |
Try a hot rod catalog! Three to three and a half is a common pipe size in exhaust systems! Try JEGS they stock a lot of transition pipe and in stainless. YMMV, regards John L |
Post Number: 236 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 12:46 pm: | |
$40 for an elbow |
Eric Hedge (Ekhedge)
Registered Member Username: Ekhedge
Post Number: 2 Registered: 6-2009 Posted From: 70.149.140.195
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 12:47 pm: | |
I'm With junkman42 on this one! Hot rod shop or even a good muffler shop should stock PLENTY of 3.5 pipe! A muffler shop could even bend it to your needs! |
Post Number: 237 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 21, 2010 - 12:59 pm: | |
like i said $40 at the napa store for just the elbow and the only muffler shop in town has no 3.5 inch also napa sells 10 foot sticks and will not cut. i have a tailpipe expander i will try to use on a 3 inch pipe from home depot. |
