Post Number: 1172 Registered: 10-2006 Posted From: 76.248.150.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 7:01 am: | |
We are finally going to get a bigger toad. Our choice is Honda CRV , it can be flat towed with an auto tranny , and has a timing chain , no timing belt to destroy the engine. There are 3 companies that make base plates , all similar priced about $300 . Blue OX ,Roadmaster and Demco . The fitting instructions on line seem similar , so does anyone have some input? All seem to need a trim of some plastic ,not a big deal , as out VW Diesel toad is a 1980 , so resale is not a factor. Any good or bad experiences with these mfg? Things to watch out for? FF |
thomas flocks (Taflocks)
Post Number: 259 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 7:21 am: | |
i have the roadmaster and it works fine but i hate my crv,,, too damn small for a fat-boy |
Bill Gerrie (Bill_gerrie)
Post Number: 355 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 9:15 am: | |
FF I have used Remco base plates on 4 different vehicles and never had a problem. On my Sebring they didn't have an exact listing so they sent a base plate for a Breeze. They worked with me to see if it would work and when I told them it fit they now list it for the Sebring as well. A great company to deal with. Bill |
Greg Roberts (Eagle 20) (Gregeagle20)
Registered Member Username: Gregeagle20
Post Number: 285 Registered: 4-2002 Posted From: 72.0.43.244
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 11:45 am: | |
I love my Blue Ox set up on the Jeep Liberty. The Jeep Liberty is actually a very good toad too. |
Mark Renner (Boomer)
Post Number: 212 Registered: 11-2006 Posted From: 206.58.200.38
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 12:10 pm: | |
Try hitchtrader.com. You might find a good used one for half that price. |
Post Number: 1173 Registered: 10-2006 Posted From: 76.248.150.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 12:41 pm: | |
Hitchtraider.com was a good idea , but no luck. Lots of other towing goodies tho ! The new CRV takes hours to take a large part of the front of the car apart , so someone really has to need what they would get for the used baseplate , 3 or 4 hours of work! FF |
Mike Heron (Mike_in_ga)
Registered Member Username: Mike_in_ga
Post Number: 15 Registered: 1-2006 Posted From: 74.190.180.236
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 5:26 pm: | |
Fred-.Have has two Roadmasters - both were fine. We have towed a Honda CRV automatic for six years - love it. Mike in GA |
Post Number: 359 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 6:02 pm: | |
I had a CRV and it worked fine as a towed. When we traded it, it just wasn't worth the time and trouble to remove the baseplate and restore the car to original. I doubt you will find any used ones out there. It took me about half a day to install with significant drilling, hammering, and cussing. As I understand it, the new (2010) CRV's are no longer approved for towing. I don't know if it is a drive line change or just a warranty issue. |
Post Number: 1177 Registered: 10-2006 Posted From: 76.248.150.30
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 6:58 am: | |
"As I understand it, the new (2010) CRV's are no longer approved for towing. I don't know if it is a drive line change or just a warranty issue." Before plunking down the deposit I checked the Owners Handbook , and towing is OK, just every 8 hours there is a lube the tranny procedure that's required. Start, shift thru the gears ,shut down. Max tow speed limited to 75 UGH! I stop more frequently than every 8 hours to drain the Belly Tank, so it wont be a bother . FF |
Post Number: 269 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 8:14 am: | |
what is drain the belly tank? sounds dirty? |
Post Number: 455 Registered: 10-2004 Posted From: 173.77.207.138
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 8:55 am: | |
Do you miss the bicycle made for 2? I loved when i only needed a bike on the back. Less worries!  |
ned sanders (Uncle_ned)
Post Number: 87 Registered: 5-2005 Posted From: 74.235.105.26
Rating:  Votes: 2 (Vote!) | Posted on Tuesday, May 11, 2010 - 2:08 pm: | |
David Fred put the two seated bike off on me several years ago at jacks rally at horizon coach.I still get it out and ride it when my grandaughter will ride and paddle for me. uncle ned |
George Martinez (Foohorse)
Post Number: 128 Registered: 1-2010 Posted From: 174.48.6.180
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 9:15 pm: | |
I am guessing that ( drain the belly tank has something to do with Ballast? |
