christopher l cole sr. (Muziklvr)
Registered Member Username: Muziklvr
Post Number: 85 Registered: 7-2006 Posted From: 69.171.173.55
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 16, 2010 - 9:52 pm: | |
i have just finished fabbing the new hitch and xtra support for it.was wondering if any of you guys could explain how to wire my 4104 for trailer lights,and also for the electric brakes for my master tow car dollie.the car dollie has a 6 pin wiring harness.is this hard to do since the bus has air brakes and the dollie has elec brakes? do i still need a brake control box up front in the driver compartment??? any help would be greatly appreciated. |
Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 97 Registered: 5-2005 Posted From: 174.42.233.129
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 5:09 pm: | |
My 4106 had a control installed by the previous owner when I bought it 7 years ago. Lights are controlled from the rear turn and tail lights. I didn't like the way the stoplight isolator worked, so I added stop lights on each fender. Electric brakes are controlled by the stop lights with a controller up front determining how strong to apply. My Master Tow has a 7 pin wireing harness and yours should too. |
George M. Todd (George_todd)
Post Number: 1020 Registered: 8-2006 Posted From: 99.29.76.171
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 8:19 pm: | |
Chris, You still need an electronic brake control box. It will need one wire wired to an ignition hot, or a battery hot source, depending upon the controller. One to the brake lights, and one to the brake pin of the trailer connector. G |
steve wardwell (Steve_wardwell)
Registered Member Username: Steve_wardwell
Post Number: 14 Registered: 2-2010 Posted From: 75.250.82.39
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 8:51 pm: | |
if yours is a 24 volt bus you will need 24v.x12v. relay switches to run your 12 volt trailer/toad......for the controller use a 12v. source (hot feed) .... use the pedal switch source (found over the spare tire) thru a relay to activate the breaking unit with 12v....brakes,run lights,signals will need relays also.....often times I've seen a separate box in the engine rm for this because the relays and wiring take up a fair amount of room 6"x12"x3" would work well |
Post Number: 15 Registered: 2-2010 Posted From: 75.250.82.39
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 8:59 pm: | |
typo error: the brakes will not need a relay in the rear eng. rm. ..this will already be stepped down and brought to the rear from the controller up frount |
Post Number: 88 Registered: 7-2006 Posted From: 69.171.173.98
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 10:32 am: | |
george,thanks for the info(and steve).my 4104 is a 12 v system.george when you say a wire to the brake light do you mean to the brake light on the bus ?? how does it wire to the brake light? |
Post Number: 18 Registered: 2-2010 Posted From: 75.202.246.244
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 20, 2010 - 10:27 am: | |
the controller uses 2 hot leads 1 is to power the unit... the other is for the actual brake controlling. It needs to know when to apply the brakes ..this is done by picking up a 12 v. lead from the pedal switch /air switch. the third wire is a ground. the forth wire goes to the bus rear to controll the braking of the toad...(make sure that the air/pedal switch is indeed 12 v. at this point otherwise you will need to use a relay |
