Patrick levenson (Zubzub)
Post Number: 216 Registered: 5-2007 Posted From: 70.52.29.11
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 9:11 pm: | |
the back of a 6-71? Do all the other -71 share this part? How about the -92? Thanks for any and all info. Patrick. |
Post Number: 418 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 10:40 pm: | |
Patrick I believe you are referring to the flywheel housing, there are for the most part two versions sae #1 and #2 and for our old bus applications you will find the #1 the most common. Joe. |
Post Number: 419 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 10:46 pm: | |
not sure if the flywheel housing is interchangeable between 71 and 92 versions. If you need to know, I will have to take a tape measure and check. |
Post Number: 420 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 10:50 pm: | |
should have read the fine print in the heading. |
Post Number: 421 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 11:10 pm: | |
Still donot have #, but 71 and 92 are not interchangable,71 has 5bolts and92 has 6 bolts for mounting. Flywheel housings are quite different also. Joe. |
don goldsmith (Bottomacher)
Post Number: 273 Registered: 12-2000 Posted From: 68.223.70.93
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 18, 2010 - 9:14 am: | |
I may have one. Email me off the board if interested and I'll try to get a photo. |
Post Number: 477 Registered: 2-2001 Posted From: 184.0.3.170
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 18, 2010 - 11:49 am: | |
Patrick, aren't you talking about the accessory drive that bolts onto the flywheel housing and has a pulley to drive your alternator? Not the flywheel housing itself. |
Post Number: 422 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 18, 2010 - 2:49 pm: | |
Jim That is correct, but sometimes we answer without really knowing what the question really asked for. Joe. |
Post Number: 1898 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 18, 2010 - 5:57 pm: | |
Check with Leid Diesel in Newville, Pa. I'm positive they would have one. 717-776-7725 |
Post Number: 219 Registered: 5-2007 Posted From: 174.93.212.231
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 18, 2010 - 6:23 pm: | |
I'll try to clarify but as I don't have any part #s/names so it is a little hard to be clear. I am looking for the accessory drive housing and bits that bolt (using 5 bolts) onto the back of a 6-71. It bolts on gear train cover (above the flywheel cover) where a gear driven generator/alternator would usually be. There seem to be a few different ones out ther. A part # would allow me to order one online . |
Post Number: 1900 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 18, 2010 - 8:38 pm: | |
call Leid... they supplied ours; just tell them what you want. They were also used on 8-71's and 6-71's in over the road trucks, since they used belt drive alternators. |
Donnie Daugherty (Dr_detroit)
Registered Member Username: Dr_detroit
Post Number: 11 Registered: 3-2008 Posted From: 74.87.222.155
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 1:32 am: | |
There are two types of accessory drives, one with a bearing assy in the cover and the other with only a seal in the cover since it flanges directly to the camshaft gear without a coupling like the other. I will try to attach photos of both types complete with part numbers. The pics were too big to attach, I will send them to your e-mail that is listed in your profile. You might want to check your spam folder for mail from dr_detroit_98@yahoo.com Donnie Daugherty Enterprise Alabama PD4106-2772 |
Post Number: 220 Registered: 5-2007 Posted From: 174.93.212.231
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 6:01 am: | |
Thanks Donnie. |
