Jaime Martinez (Jaime)
Registered Member Username: Jaime
Post Number: 9 Registered: 4-2009 Posted From: 67.142.130.33
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 5:35 pm: | |
I am on the road having an issue throwing fan belts. I have a 1967 MCI 5a with an 8v71 with a spring loaded pulley which is making a gravely noise. I do not think it is the bearings as the seem good and everything seems to rotate quietly with belt off. I will see if I can post a photo of the pulley it does not seem to be separating evenly while the belt is spinning which I believe it should. I am not familiar with this type of pulley system so any advice would be appreciated. I am currently at a rest area west of FT Stockton,Texas |
Post Number: 10 Registered: 4-2009 Posted From: 67.142.130.33
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 6:00 pm: | |
Here is the photo of the Pully
Glen Rice (Rgrauto)
Registered Member Username: Rgrauto
Post Number: 10 Registered: 2-2006 Posted From: 98.18.126.169
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 6:56 pm: | |
Jaime, Is the belt tight enough to keep the belt from walking out of the pulley? On my 67 mci 5a there is two adjusting bolts and nuts that lifts the gearbox up or down to adj. the belt. If there is nothing loose to cause movement, I think I would tighten the belt and see what happens. HTH Glen Rice |
Post Number: 11 Registered: 4-2009 Posted From: 67.142.130.33
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 7:14 pm: | |
Thank you Glen for the reply I have tightened the belt with the below instructions and even a little tighter ¼ inch.
Greg Roberts (Eagle 20) (Gregeagle20)
Registered Member Username: Gregeagle20
Post Number: 286 Registered: 4-2002 Posted From: 72.0.43.244
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 10:15 pm: | |
Jaime, The fit of the pulley may be hanging and causing a loose/tight situation as the pulley turns. I would remove the belt and then spray some WD-40 on the fit and then work it in and out with light taps of a hammer (dead blow or regular with a piece of wood to cushion the blows). Work it until it moves evenly and stays straight. Then take some alcohol or other solvent and clean off the pulley so that the belt will grip. Alternately you could take it apart and clean it up too but probably not the best place to do that unless you have to. Hope that helps. - Greg (Message edited by gregeagle20 on May 19, 2010) |
Post Number: 12 Registered: 4-2009 Posted From: 166.183.146.84
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 20, 2010 - 12:08 am: | |
Thanks for the response Eagle20 I was also posting on the other board and received simular advice and it seem to have worked and I am happy to say I have gone 80 miles and not thrown a belt yet I will be resting up for the evening and heading out early. hopefully this will get me home and then I will tear into it. once again thanks to all. |
Gary Stacy (Stacytruck)
Registered Member Username: Stacytruck
Post Number: 16 Registered: 12-2009 Posted From: 75.170.78.9
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 20, 2010 - 1:37 am: | |
Hope that gets you home, and BTW beautiful Bus. g |
Post Number: 74 Registered: 1-2009 Posted From: 69.171.160.204
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 20, 2010 - 3:07 am: | |
Penetration-cleaning & then lubrication liquids...in that order Greg, I agree with you except for 2 items. The seems to be no water to displace so the Missile skin dew repellent (wd-40) isn't called for. CRC 3-36 is a better product but still might not have the deepest penetration properties available. See the post on Mouse Milk/PB Blaster lower down on the front page. If the problem seems to be associated with grease hardening & dirt impaction as opposed to rust, try carb cleaner or starting fluid , which is nothing but Either, the worlds best de-greaser south of liquid Freon. Ventilation & common sense around any of the above is in order. Or at least that's my SOP FWIW |
George Martinez (Foohorse)
Post Number: 145 Registered: 1-2010 Posted From: 72.153.247.232
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 20, 2010 - 11:09 am: | |
why must we keep bringing up mouse milk. just when I get over it. someone has to introduce it into a thread again. oh well a double dose of Marvin's meds and the tremors should subside soon enough. THANKS JACK. |
Post Number: 13 Registered: 4-2009 Posted From: 32.176.80.124
Rating:  Votes: 1 (Vote!) | Posted on Thursday, May 20, 2010 - 1:19 pm: | |
Made it to El Paso no issue, Penitrating oil seems to have done the trick. Thanks to all. |
Post Number: 287 Registered: 4-2002 Posted From: 72.0.43.244
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 20, 2010 - 8:43 pm: | |
Glad you are safely on your way. Being stranded is a real pain! |
Post Number: 75 Registered: 1-2009 Posted From: 69.171.160.58
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 4:42 am: | |
"why must we keep bringing up mouse milk"... I don't know George, when I drink it, it stays down for me, whose this "we" you speak of? Maybe it's your mix or the monkey chow, didja ever give them any thought? Marvi's Meds.....tremors?... SO Cal wants to get rid of them, can you stand of the roof of a moving Bus with a shovel? Just an idea..... |
Jim Shepherd (Rv_safetyman)
Registered Member Username: Rv_safetyman
Post Number: 306 Registered: 1-2004 Posted From: 75.221.33.220
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 7:52 am: | |
Jamie, glad that it seems to be working. When you get home, I would get a new belt. Once a belt has turned over (would guess yours did), the outer cords are damaged a bit and it will be prone to turn over again. I would keep this belt as an emergency belt. Sounds like the sheave half was bound up on the shaft. Jim |
Post Number: 1176 Registered: 11-2005 Posted From: 24.251.120.104
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 2:40 pm: | |
I truly apologize for ever mentioning mm and have been sorry ever since!! A worn pulley bearing will make a grinding sound under load and not make it when unloaded. |
Post Number: 362 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 3:00 pm: | |
Post Number: 912 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 5:33 pm: | |
Help Us All !! LOL Gotta git to the drug store!! I need a fix. |
Post Number: 76 Registered: 1-2009 Posted From: 69.171.160.114
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 11:48 pm: | |
Ah! Len, the only fitting response is YES......!!! |
