Randi Scott (Superand)
Registered Member Username: Superand
Post Number: 13 Registered: 1-2008 Posted From: 76.16.220.96
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 11:03 am: | |
hi all - i have a powertech 17.5k gennie, and my VR went out. i have ordered a new one and will be installing myself. wondering about "tuning" it for the correct output. any words of wisom ?? |
FloridaCliff (Floridacracker)
Post Number: 430 Registered: 7-2004 Posted From: 97.101.146.143
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 2:31 pm: | |
Randi, I have a 8Kw powertech and its VR is a sealed unit. Cliff |
Post Number: 485 Registered: 2-2001 Posted From: 65.15.106.226
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 10:08 pm: | |
If it will need adjustment, it should come with a how to instruction booklet. |
George M. Todd (George_todd)
Post Number: 1022 Registered: 8-2006 Posted From: 99.29.76.171
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 21, 2010 - 10:59 pm: | |
120 Volts, period. G |
Tom Christman (Tchristman)
Post Number: 219 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 22, 2010 - 11:37 am: | |
The only real adjustment on the Powertech (I have a 10kw) is the rpm of the engine to control AC cycles. I have mine adjusted to 62hz at no load which brings it to right at 60-61hz when two A/C's are running. Best to be in the 59-61hz range for motor running. Good luck, TomC |
