Post Number: 407 Registered: 9-2007 Posted From: 96.42.5.35
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 23, 2010 - 3:25 pm: | |
Maybe someone can tell me on my 4107 with 8v 71 N and cable pull accelerator, how can I tell if my foot flat on the floor is really opening up the motor all the way? It seems like I should have more travel and top end like maybe it needs some adjustment. Thanks in advance for any advice. John |
Gary Stacy (Stacytruck)
Registered Member Username: Stacytruck
Post Number: 17 Registered: 12-2009 Posted From: 75.170.78.9
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 23, 2010 - 3:50 pm: | |
The easiest way I know to check, is to have someone push the pedal, while you check the travel on the governor, should be a quick way to tell. g |
Patrick levenson (Zubzub)
Post Number: 222 Registered: 5-2007 Posted From: 174.91.228.43
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 23, 2010 - 4:40 pm: | |
or a stick. That reminds me, back in the day, when I hitchhiked a lot, met a few truckers who used a stick to hold the pedal down. They like to call it cruise control, raelly they were jsut running against the governor, but they seemed to enjoy it. Some had a ratcheting kind of rig....others just used a stick jammed under the dash. |
Post Number: 486 Registered: 2-2001 Posted From: 65.15.106.226
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 23, 2010 - 7:45 pm: | |
With the throttle cable clevis pin removed at the governor end, someone (or something) holding the pedal down, I pull the cable clevis back with one hand to eliminate slop and crank the governor wide open with the other, the pin should drop cleanly in place. No, I don't have three hands. The governor hand can do the clevis pin. (Thought I'd better clarify before we got out of control here!) (Message edited by pd41044039 on May 23, 2010) |
Post Number: 487 Registered: 2-2001 Posted From: 65.15.106.226
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 23, 2010 - 7:46 pm: | |
Sorry, hit button twice. (Message edited by pd41044039 on May 23, 2010) |
Post Number: 408 Registered: 9-2007 Posted From: 96.42.5.35
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 23, 2010 - 11:31 pm: | |
Good info, I will try it tomorrow. Thanks all John |
