Joe Franklin (Franklinga)
Registered Member Username: Franklinga
Post Number: 10 Registered: 1-2005 Posted From: 192.206.119.3
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 01, 2010 - 4:34 pm: | |
My manual does not list all the part numbers. I need to know the P/N's for the fuel pump and the coolant temperature (water) sending unit on my MC9 with an 8v71 engine. I can't find anything on line for the sending unit, and it looks like there might be at least a couple of different part numbers for the fuel pump. Anybody have the correct numbers? Thanks for your help. |
Bob MacIsaac (Wildbob24)
Post Number: 100 Registered: 5-2007 Posted From: 98.92.174.62
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 01, 2010 - 5:48 pm: | |
Joe, DD number for the fuel pump is 5199561. Can't help with the temp sender, but you might contact MCI parts (800) 323-1238. They can probably help. Bob |
Post Number: 665 Registered: 5-2007 Posted From: 64.40.216.52
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 01, 2010 - 11:35 pm: | |
The sending unit might depend on the gauge, as they are usually only compatible to each other. VDO gauge, VDO sending unit is what I have on our Eagle. |
