Dave Walker (Chrome_dome)
Post Number: 41 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 06, 2010 - 11:14 pm: | |
Anybody Know; Where I can order or buy (and whats a good Price for)a Fuel tank sending unit for a 1979 MCI 5C-s 144 gallon Tank. Already tested the MCI Gauge and it works fine except when hooked to the SU. 6V-71 Plus need exhaust manifold gaskets, I am near Sacramento, CA Area Want to replace them all in the next few Months. Thanks to any info you have. Dave |
Patrick levenson (Zubzub)
Post Number: 231 Registered: 5-2007 Posted From: 174.91.225.176
Rating:  Votes: 1 (Vote!) | Posted on Monday, June 07, 2010 - 1:24 am: | |
Just a thought...pull the SU and see what's wrong, sometimes components just need a little love to start working again. Too many times I have purchased a replacement unlt to discover when I pull the part that a little emery paper here a little twist there and it's working again...also is it the SU or the wiring from the su to the gage? |
Post Number: 42 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 9:38 am: | |
Thanks Patrick, Ya know sometimes the little things get overlooked. I will pull it out and cleaner Up and see if it starts working again. Dave |
Post Number: 615 Registered: 1-2005 Posted From: 97.104.18.110
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 10:46 am: | |
http://www.egauges.com/vdo_sgrp.asp?Subgroup=Fuel_Senders |
Mark Renner (Boomer)
Post Number: 214 Registered: 11-2006 Posted From: 206.58.200.38
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 08, 2010 - 12:44 pm: | |
Quite often the floats will leak. If the guage reads a constant "empty" that is where I would look first. When you hold the assembly in your hand, the float and arm will just fall to the bottom. You can replace the float, or drill a small hole in it, drain all fuel out, then seal the hole with epoxy, or something similar, or maybe solder if you are careful. |
Post Number: 43 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 09, 2010 - 10:15 am: | |
Thanks you guys for the good info. It was just old and needed to be worked like Patrick had mentioned. The gauge always showed pegged or way past full -KEY OFF. Turn KEY ON and it dropped to empty. Had a thought though; If I put in a toilet Float and hooked the fuel line to the black tank, I could run off the gas for a long time, Call it BIO-BURRITO, No just kidding.HA,HA,HA Dave |
Post Number: 927 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 09, 2010 - 4:46 pm: | |
Dave....!! you are starting to sound like something Chessie would do. lol lol gomer |
