Lloyd Greer (Mcbud) (209.226.118.77)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 15, 2003 - 6:58 pm: | |
How can you tell if your allison transmission is slipping |
Ed Jewett (Kristinsgrandpa) (67.74.5.199)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 15, 2003 - 8:26 pm: | |
If you have a tach. it might indicate slippage, but maybe not,if only a little slipping occurs. It probably would be too inaccurate to figure the final drive ratio/gear ratio/tire circumference, but you might compare with someone that has a similar setup if he also has a tach. I've been pondering the same question since my coach has an HT 748 and doesn't have a tach. |
Johnny (67.241.232.4)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 15, 2003 - 8:47 pm: | |
With a temp gauge, it will usually run hot if it's slipping. If you don't have a trans temp gauge, well WHY NOT?! |
smoky (12.222.48.5)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 15, 2003 - 11:37 pm: | |
Lloyd, which gear do you think is sliping? Smoky |
