Barry McCully (Turtle)
Registered Member Username: Turtle
Post Number: 37 Registered: 8-2007 Posted From: 71.7.161.192
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 21, 2010 - 5:05 am: | |
Haven't hard time to open mc-9 door with outside push knob. |
Post Number: 1170 Registered: 7-2006 Posted From: 74.162.79.161
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 21, 2010 - 7:35 am: | |
My 9 used to settle when the air was out, and the door would jam in the frame. I took a small piece of flat PC-type plastic, and taped it to the push lever mechanism under the dash. It added about a 1/4" to it, allowing it to give a more full push when I hit that outside stub. Prior to that, I had to pry the door at the bottom to get it un-jammed. |
Post Number: 1886 Registered: 12-2000 Posted From: 174.89.176.108
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 21, 2010 - 10:24 am: | |
How is the door for "locking"? The solution above is a good one, it handles the lack of throw for the push button, taking up any slack space to your advantage. If the over-centre mechanism is getting hard to push, a slight adjustment of the door turnbuckle, in under the cover, might help. Assuming everything is lubed and free before you try adjusting.... Be sure to mark where you are, and carefully count the degrees and or revolutions of adjustment, so you can get back to where you started, it is easy to make things wildly worse, and time consuming to get back. Usually, the harder you set it so the door doesn't casually lock, the harder you have to slam the door to lock it, and the harder you have to push the button to break the over-centre mechanism. It's all a balancing act. happy coaching! buswarrior |
George Martinez (Foohorse)
Post Number: 175 Registered: 1-2010 Posted From: 72.144.22.70
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 22, 2010 - 8:29 pm: | |
80 post stupid bus door thread?. it could be fun. |
