Grant Thiessen (Busshawg)
Post Number: 267 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 03, 2010 - 11:41 am: | |
I have replaced wheel bearings and wheel seal, how far should the test drive be before I would feel comforatble that this thing insn't going to leak. I messed up filling oil, I filled through the power divider plug which over filled it. On my first test run it pushed oil out the vent. I went home drained oil to the proper level , then took it on another 40 mile test run and all is dry. Is this far enough to feel comfortable that I didn't blow the seal?? |
Post Number: 268 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 04, 2010 - 9:32 am: | |
well I ended up running about 50 miles through some hills and all is good, whew |
Post Number: 438 Registered: 9-2007 Posted From: 96.42.5.35
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 04, 2010 - 10:41 pm: | |
Good job Grant. i would have replied to your last post but anything I said would have been a guess. Good luck. John |
