Kenneth Hintermeister (Barbwire)
Registered Member Username: Barbwire
Post Number: 18 Registered: 6-2005 Posted From: 205.188.116.203
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 17, 2010 - 3:36 pm: | |
Rebuilt my Onan marquis 7000, Wanted to run it on the bench, Does it have to be hooked up to the remote start and hourmeter or elect panel? starter just kicks in intermitently, won't spin over. |
George M. Todd (George_todd)
Post Number: 1095 Registered: 8-2006 Posted From: 99.56.240.204
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 17, 2010 - 7:00 pm: | |
Ken, Sounds like you don't have good enough connections to your bench battery, or the wires are too small. G |
Post Number: 301 Registered: 10-2006 Posted From: 99.23.142.159
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 17, 2010 - 10:55 pm: | |
I have had the experiance with Onan that the end terminals are all suspect to intermittent and or loss of contact. Both behind the panel with the start switch and also on the end of the buisness end on the gen there is a access cover where some wires terminate and I have seen loose. View every end terminal as suspect clean every one. |
Bob Wies (Ncbob)
Registered Member Username: Ncbob
Post Number: 269 Registered: 2-2006 Posted From: 64.85.179.73
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 21, 2010 - 6:36 pm: | |
With a fully charged battery and an alternate source of fuel all things being equal the generator should run. Be sure to keep the cooling exhaust off the bench. Isolate the output leads and once it's running smoothly adjust the governor to 61 HZ, no load. If it won't crank consult your Service Manual..I'm sure you didn't do an overhaul without one. By the way the DC leads to the slip rings are polarity sensitive. NCbob |
