Help with tag axle Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » May 2003 » Help with tag axle « Previous Next »
Harry G (142.173.199.78)
Posted on Wednesday, May 21, 2003 - 9:28 am:
I need to remove drivers side tag axle as it is stuck. Has anyone done this and could someone please give me any tips on the best way to remove this?
thanks in advance
Harry G (Tin Lizzy)
Doug Dickinson (Dougd470) (65.161.188.11)
Posted on Thursday, May 22, 2003 - 10:18 am:
When you say "Remove it" do you need to move the coach somewhere or are you replacing something major?
On some coaches, you can remove the wheel and chain up the Tag to operate the bus for short periods.
ralph7 (208.171.8.139)
Posted on Friday, May 23, 2003 - 6:08 pm:
my parts book shows a clamp with 4 bolts .remove bolts an clamp (outre washer is split an inner washer is not split. NOW Pull an if your luckey it will come out . let me know ,but this is a HEAVY item.
