thomas flocks (Taflocks)
Post Number: 340 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 4:59 am: | |
anyone know how i can get the squirrel cage of the motor or dose anyone have a good unit for sale cheap? i have tried pb blaster and a big hammer but it will not budge, |
Post Number: 972 Registered: 3-2007 Posted From: 71.55.13.161
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 11:38 am: | |
Tom, I think that if you take a little torch and heat it[hub] and apply PB on it and keep doing it, it will probably let loose. It may take several times and let it set for awhile. I sprayed PB on it, heated it to where it would boil and then spray some more on it and try to tap it with a hammer not to break it but get its attention and keep trying it. Gomer |
Jim Wallin (Powderseeker01)
Post Number: 88 Registered: 10-2008 Posted From: 72.37.244.90
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 6:44 pm: | |
I have a friend that may want to part with the ones from our 4107. Don't know if they will work for your 4106 or not. |
Post Number: 1949 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 9:21 pm: | |
Be careful that you don't mushroom the end of the shaft even a little bit or you'll never get it off intact. If this did happen, patiently dress end with a file and compare to rest of shaft with calipers or micrometer, If then you can attach vice grips between end of cage and motor on shaft to act as a heat sink, you can use an acetylene torch to heat cage hub till it comes off. Make sure there isn't a second allen screw behind the regular one. I've seen them doubled up sometimes. Also look for another screw in another location on other side opposite or 90 degrees away. |
Post Number: 346 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 2:34 am: | |
i already mushroomed it............. |
Post Number: 1952 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 5:11 pm: | |
if a file won't fit, use a Dremel tool. If you don't have one, now is a great excuse to get one. |
Post Number: 1292 Registered: 10-2006 Posted From: 99.153.142.249
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 29, 2010 - 8:49 am: | |
Messing about in Boats and Buses , with an occasional Honey Do as a "Bonus Job" , my favorite toy is the mini router the wall board guys use to cut electric box holes . Fitted with a 1/4 shank rotary cutting bit of different diameters or taper , it REALLY removes material. Fast and cheap to buy & keep, MY WAY, FF |
Brandon Merritt (Brando4905)
Registered Member Username: Brando4905
Post Number: 26 Registered: 3-2009 Posted From: 74.97.202.43
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 31, 2010 - 8:14 am: | |
This is what you need---- http://www.amazon.com/gp/product/B001CGFQDW/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=486539851&pf_rd_ s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0002SRH60&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=03YEDXSR18 67PT93YN7A |
