Post Number: 1042 Registered: 10-2004 Posted From: 75.203.148.213
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 01, 2010 - 10:04 pm: | |
I have a new to me (6 months old) radiator on the truck coming south to me and should be here in a couple of days. Mine is not leaking but it's in sad shape visually! Anyway, I took the time today to start the installation of a mister and the trials show that it will work really well. It's all plumbed and only thing left to do is run 12v wires to the drivers area with a toggle switch. The actual mister is an easy on and off application at the radiator so when it comes time to remove the old and install the new, it will be a snap! The mister I found about 4 years ago and never installed it. It cost me 5 bucks at a wal-mart discount isle and was made to go around a patio umbrella. It is plumbed using an isolated shur-flo water pump and glad that it works good! I know it's more or less a band-aid but none the less, down here a band aid is sometimes needed when it's hot out. Ace |
Cable (Fe2_o3)
Registered Member Username: Fe2_o3
Post Number: 52 Registered: 10-2004 Posted From: 108.17.169.121
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 01, 2010 - 11:24 pm: | |
I have a mister also and was playing with the idea of using the 190 deg. warning sending unit to turn it on. Any thoughts?...Cable |
Bill Gerrie (Bill_gerrie)
Post Number: 377 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 01, 2010 - 11:53 pm: | |
Cable It would run constant at 190 degrees when the switch closes. You will only need it once in awhile when you see the temp rising. You would also need too big a water tank. I only need ours for a few seconds when it is needed then the temp drops to an acceptable level. Bill |
steve wardwell (Steve_wardwell)
Registered Member Username: Steve_wardwell
Post Number: 87 Registered: 2-2010 Posted From: 75.200.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 02, 2010 - 6:02 pm: | |
and make sure you use distilled or RO water I found that out the hard way...........s........ |
Post Number: 977 Registered: 3-2007 Posted From: 71.55.13.161
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 02, 2010 - 9:45 pm: | |
why don't someone come up with a cooler thats made like a moonshine still and run the coolant water thru it, cool it down thru the coils and problem would be solved with misters,extra fans and all the acc. We all have generators big enough to handle the load.. Just thinking out loud. Gomer |
Bill 340 (Bill_340)
Registered Member Username: Bill_340
Post Number: 114 Registered: 7-2006 Posted From: 75.197.194.245
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 02, 2010 - 10:56 pm: | |
You think Ace was kidding, here is a picture of the local ice cream truck in his neighborhood.. NOW thats funny, I dont care who you are, thats funny..... |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 161 Registered: 12-2000 Posted From: 32.179.184.60
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 07, 2010 - 8:52 am: | |
Bill that photo is really cool or should I have said really HOT!!! |
Post Number: 1046 Registered: 10-2004 Posted From: 75.202.155.35
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 07, 2010 - 8:57 am: | |
LOL that IS funny! Thanks Bill! |
