Registered Member Username: Sylverstone_pd4501864
Post Number: 272 Registered: 7-2005 Posted From: 207.14.38.124
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 02, 2010 - 7:44 pm: | |
greetings so while i'm putting together all the parts for my series 60 / 10 speed autoshift conversion, i happened to fall into an 8v-71 that runs like a top. so i'm thinking about putting it in my bus so i can drive her while i parts chase. but that won't solve the "pops out of every gear" thing. it looks like about 10,000 miles ago someone did a transmission oil swap and used synthetic in it. not sure if this is the cause, or if it's linkage, or the transmission itself. i had someone just point out to me that we may not be able to rebuild the one in there due to lack of parts availability... can anyone shed any light on this? suggestions on who, in the seattle area, can handle rebuilding this transmission? thank you, -stone http://www.scenicruisers.com/ |
Post Number: 1297 Registered: 10-2006 Posted From: 99.153.142.249
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 03, 2010 - 5:53 am: | |
not sure if this is the cause, or if it's linkage, or the transmission itself. DA BOOK has the complete info on setting the shift rods and clutch linkage. At least on our 06 ,should be info on how to set up the senicruser, if it has a book. Your 10 speed have OD? The 8v71 will usually be at 1900rpm or so at cruise the series 60 will be about 1300 rpm . FF |
Tom Christman (Tchristman)
Post Number: 247 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 03, 2010 - 7:49 am: | |
On the 10 spd autoshift, depending on the model, the overdrive could be .73-.75. That translates with a direct drive cruise at 1900rpm, dropping to 1387rpm to 1425rpm which is perfect for the Series 60. Good Luck, TomC |
Post Number: 1957 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 03, 2010 - 7:59 am: | |
jumping out of gear could be mis adjustment, worn shift forks or too much gear end play. I'd at least pull top off of trans and inspect shift forks for excessive wear and check for too much end play in gear/shaft assemblies. Those clearances should be pretty much the same as any other GM trans. If forks are worn excessively and new are unobtainable, proper welding and grinding could repair those surfaces. |
Post Number: 141 Registered: 10-2004 Posted From: 24.62.45.179
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 06, 2010 - 4:47 pm: | |
Why do you want a 10 speed autoshift? Don't they make 5 or 7's yet?I currently drive a #$*^box Freightliner with one of those assinine 10 speeds.Every time you stop at a light it will go through all ten gears again and again. Absolutely maddening.I have a sraight 5 speed in my Crown and have plenty of gears. |
Post Number: 607 Registered: 9-2004 Posted From: 65.23.106.193
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 07, 2010 - 10:02 am: | |
Bassically a standard spicer 4 speed. The main difference is the shifter. Make sure the shifter plate is securely bolted to the transmission - if loose, it can cause your problems. Check for propper shifter adjustment & that it is fully engaging the gear, not just half way. Ask around, you may be surprised by how many good used scenicruiser transmissions are sitting on the floor waiting on a good home ;-) I know of more than one here on the East coast . . . . . |
Bob Wies (Ncbob)
Registered Member Username: Ncbob
Post Number: 275 Registered: 2-2006 Posted From: 64.85.179.73
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 24, 2010 - 4:14 pm: | |
And you own all of them. hehehe NCbob |
