J.Lee (65.29.64.100)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 01, 2003 - 8:04 am: | |
went to work on bus and it is sitting on front wheel on passager side bad air bag?? if so where can i get one and how hard are they to put on ???any help ON A MCI thanks J.Lee |
Jim Ashworth (Jimnh) (172.203.42.126)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 01, 2003 - 7:26 pm: | |
The MCI has only one levelling valve in the front. Both sides always have even pressure unless the levelling valve has been removed to install a manual levelling system. All side to side tipping normally comes from the rear valves. Sounds like you have a leak in the rear suspension on the passenger side, otherwise both front wheels would be sitting on the bump stops. Jim |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 02, 2003 - 7:02 am: | |
OK WILL TAKE A LOOK AT IT THANKS J.Lee |
Brad Steward (142.177.12.50)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 16, 2003 - 9:40 pm: | |
The bags are not hard to change - the biggest problem is getting the old bolts out !! I air chiseled mine off and put in new ones. I had a leak in the frame itself so put plates on top of the bags. MCI sells them as well !! Cheers Brad |
