RayOlson (216.43.213.97)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2003 - 9:20 pm: | |
There is no gear pattern for these transmissions. They work just like an automatic, but it shifts thru 10 gears like a manual. The touch pad to put it in gear is just like an auto. When you start out, you push down the accelerator a little and it begins to move as if you were letting out the clutch. Once you get it rolling, you can mash the pedal down and it shifts on its own. Very easy to drive. To maintain it, ????? |
