bster (198.81.26.108)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2003 - 8:53 pm: | |
i put power steering on 04 using newer style vickers pump with remote resivor and box from transit 80s do i use 10- 40 ? |
two dogs (66.90.211.74)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2003 - 9:56 pm: | |
automatic transmisson fluid |
jmaxwell (66.42.92.5)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 14, 2003 - 12:28 am: | |
Mine is a '81 Grumman w/same pump, and specifies 30w, in the manual and on the reservoir. |
Bill Gerrie (216.185.72.14)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 16, 2003 - 9:10 am: | |
If you use a motor oil use a 5 wt. Thin as possible so when it is cool out you don't starve the pump. It makes a lot of noise if the oil is to thick till it warms up. A lot of people use transmission fluid but if the seal in the pump goes it dumps it into the crankcase. Not to good for the bearings. My 2 cents worth. Bill |
