Gerald972 (199.196.144.12)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 20, 2003 - 11:32 am: | |
I am about to install my new generator. However, I have read on this board about a return line to the fuel tank. Can anyone explain where this line comes from on the engine? I will not be using an auxillary fuel tank, just the bus tank. |
jmaxwell (66.42.92.5)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 20, 2003 - 1:19 pm: | |
That depends on the motor used on your genset. Generally, it will situated on the injector manifold or in the case of individual lines for injector feed, it will be located downstream of the supply to the injectors. On my Isuzu it is located on the injector manifold nearest the back of the engine. It is a 1/4" slip-on stub fitting. |
gerald972 (199.196.144.17)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 23, 2003 - 1:59 pm: | |
Thanks I found it! |
