les marston (Les_marston)
Post Number: 109 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 7:25 pm: | |
I have been looking at macerator toilets (marine style) for our coach. My idea is to have the black water well liquified before it goes into the tank, then to discharge it thru another pump when we dump. I am thinking that this will allow me to use a substantially smaller hose to dump as well will make it easy to dump from both sides of the coach. Anyone with pros or cons? Les |
Post Number: 171 Registered: 1-2009 Posted From: 69.171.161.117
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 7:57 pm: | |
If we'd all go on liquid diets the need for a macerator would be nil. That's my thought & I ain't sticking to it! OR you could just buy & install a stand alone macerator.... |
Dallas Farnworth (Dallas)
Post Number: 99 Registered: 7-2004 Posted From: 72.172.39.165
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 8:06 pm: | |
Or you could do something like this: http://steampunkworkshop.com/diy-rv-macerator-pump |
Jerry W Campbell (Jerry_w_campbell)
Registered Member Username: Jerry_w_campbell
Post Number: 46 Registered: 7-2005 Posted From: 206.125.84.172
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 9:48 pm: | |
I have been using a macerator pump for 7 years and don't know why you'd dump your tanks any other way. I have never used my 3" hose. It's still in the storage tube new. I don't know about a marine toilet. I don't see the need to macerate it twice. Or if there would be problems settling and be hard to totally empty the tanks. Jerry |
Post Number: 110 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 9:59 pm: | |
Dallace. I love ingenuity but using a garberator wasn't what I had in mind but I bet it works. Jerry I want to use the macerator toilet so that the waste is liquid before it goes into the tank and also so that I don't have to depend on gravity to get the black water to the tank. What type of macerator do you use to dump your tank? Please don't tell me it was made by kitchenade lol Les |
Post Number: 111 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 10:00 pm: | |
sorry about the spelling Dallas |
Post Number: 100 Registered: 7-2004 Posted From: 72.172.39.165
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 10:08 pm: | |
Les, I used a Jabsco macerator for awhile... until I ran it dry, twice. The rubber impeller costs around $50 and is a crappy job to replace. I like the idea of the garbage disposal, it's higher horsepower, has a stainless impeller, doesn't mind being run dry, will work on shore power or inverter, and can be replaced at any hardware store for under $100. |
Jim Wallin (Powderseeker01)
Post Number: 101 Registered: 10-2008 Posted From: 70.90.115.49
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 7:55 am: | |
I knew a fellow back in the 70's who used a couple of S&S Winnies for working the short track circuit in the south. He had both of them set up with macerator pumps that were plumbed right into the collector of the headers he had on the motors. He could empty his tanks in about 10 min and said he'd never had a problem with tailgaters. |
Post Number: 1321 Registered: 10-2006 Posted From: 99.168.85.180
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 8:20 am: | |
My idea is to have the black water well liquified before it goes into the tank, then to discharge it thru another pump when we dump Works great but fotgetaboutit with RV junk. A Obendorfer unit is about $800 , but will work for 30 years. Galley Maid also has good units . 120V is the best as the 12V ones go beserk if there is too thick a solution. The Galley Maid has a point to add water while pumping , the Obendorfer doesn't need the help. FF |
Post Number: 47 Registered: 7-2005 Posted From: 206.125.88.70
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 10:43 am: | |
I have a FloJet from Camping world. I have pumped uphill 150 ft. so far so good Jerry |
Post Number: 1085 Registered: 10-2004 Posted From: 75.200.167.144
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 8:28 pm: | |
Dallas, have you built one of these garbagator's yet? After seeing this, it got my wheels spinning! I just might have to try this! |
Don Evans (Doninwa)
Post Number: 285 Registered: 1-2007 Posted From: 208.81.157.234
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 8:45 pm: | |
Ace if your wheels are spinning you need to pump the waste further away!  |
Post Number: 101 Registered: 7-2004 Posted From: 72.172.39.165
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 8:48 pm: | |
I haven't built one yet Ace, but it's high on my list. |
Edward J. Sommers (Sommersed)
Registered Member Username: Sommersed
Post Number: 57 Registered: 10-2004 Posted From: 148.63.161.138
Rating:  Votes: 1 (Vote!) | Posted on Monday, October 11, 2010 - 12:26 am: | |
This is not really a new or unique idea, the garbagator. I remember at least two different discussions on the subject on two different boards some time ago. As I remember it they each came to the same conclusion, that being that while they worked for short runs, they were neither cheaper to build and were not suitable for pumping long distance nor up hill. A real macerator pump can be had for around a hundred bucks on ebay, I carry two! Ed |
Dave Walker (Chrome_dome)
Post Number: 107 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 11, 2010 - 12:35 am: | |
Dallas & Ace I am Jazzed also, and looks pretty easy, placement of the bolts is pretty critical. I looked at that too and have always wondered if you could make one out of a disposal and now I know. Thanks Dallas. I will make one soon out of the new one I bough for a back up for the house when they were on sale but never had to put it in,Now that we will be leaving to full time I know where I will need it. LOL Dave |
Post Number: 1087 Registered: 10-2004 Posted From: 75.200.22.246
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 11, 2010 - 4:25 pm: | |
Okaaaay I found me a disposal.... let the fun begin!  |
Post Number: 102 Registered: 7-2004 Posted From: 72.172.39.165
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 11, 2010 - 4:55 pm: | |
Ace, I think I would forgo the trout tube and hang the pump as close to the out tube as I could. Other than that, I have no advice, except to please let us know how it goes. I'm looking for a new or used disposal naow to see if I can build a workable model. |
Post Number: 1088 Registered: 10-2004 Posted From: 75.201.130.56
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 11, 2010 - 8:24 pm: | |
Yea that's what I was thinking along those same lines! I didn't hardly anything for the disposal so if I screw it up, no biggy!  |
Post Number: 1015 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 11, 2010 - 8:58 pm: | |
I found some info once about the install. Hook up to the lines coming from the ivory tower and the sink to the top on the unit and then you can run flex piping,like heater hose, to the side outlet and let er go right in the tank. gomer |
Post Number: 112 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 11, 2010 - 10:43 pm: | |
Just to let everyone know that we bit the bullet and ordered our macerator toilet. Got a great deal from a company that is clearing out some discontinued Dometic units. Regular retail was over $1500. We bought it for $549. I feel like we are really making some progress on the coach thanks again to everyone who gave input on this topic Les |
Post Number: 108 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 12, 2010 - 12:31 am: | |
Ace; How would it be to use an elbow bayonet fitting directly off your 3" to the top of the Opening on the Disposal and use no hose length. Some kind of pull out bracket to support the weight or ? Dave (Message edited by chrome_dome on October 12, 2010) |
Post Number: 1343 Registered: 12-2000 Posted From: 75.201.43.221
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 12, 2010 - 8:19 am: | |
I know the unit will macerate, but will it pump or do you have to rely on gravity or add a pump to the project? Sounds like an interesting project. Jack |
Post Number: 109 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 12, 2010 - 9:10 am: | |
Jack: If the guy in the article raised it 7 feet in the air and had good flow it should work? There is an impeller inside also that will push water through. If let to run dry there could be a back up but flush with water at the end should take care of that.I am sure we shall find out soon, from Ace, eh? If it hits the Fan wrong, LOL Dave |
Post Number: 412 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 12, 2010 - 12:23 pm: | |
You could add a water hose connection to the dishwasher inlet for a final flush. |
Post Number: 1090 Registered: 10-2004 Posted From: 75.201.3.100
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 12, 2010 - 11:28 pm: | |
Kind of what I had in mind for easy flushing! |
Prather Ellsberry (Prather)
Registered Member Username: Prather
Post Number: 13 Registered: 10-2006 Posted From: 32.161.175.144
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 11:21 am: | |
I have been using a rariton macerator toilet for years and like it. I originally bought it because the toilet only needs a 2 inch benable hose for discharge which makes location more flexible because it doesn't have to be over the tank. Also it has a loop seal on the discharge so no opening exposed to the tank therfore no smell. Prather |
Post Number: 115 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 9:15 pm: | |
Prather That is exactly why I went with the macerator toilet. Thanks for confirming what I believe. In the time you have had yours have you had to do any repair on it? From the discharge hose on the toilet what material did you use to go to the black water tank? Les |
Post Number: 512 Registered: 10-2004 Posted From: 173.77.223.202
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 11:37 pm: | |
Raritan makes quality marine products and i believe are still located in NJ. As far as garbage disposal units, Insinkerator makes the best in our humble opinion. I also think as long is there is plenty to pump,the disposal will pump it 7 foot head (?) i would set up the rinse option! |
Post Number: 413 Registered: 12-2000 Posted From: 72.187.35.208
Rating:  Votes: 1 (Vote!) | Posted on Thursday, October 14, 2010 - 8:14 am: | |
If you are going to use a disposal unit and the rinse option, be sure to install a back flow preventer at that connection. |
Tony LEE (T_lee)
Post Number: 74 Registered: 11-2007 Posted From: 59.154.42.140
Rating:  Votes: 1 (Vote!) | Posted on Thursday, October 14, 2010 - 10:58 pm: | |
"don't know why you'd dump your tanks any other way. I have never used my 3" hose. It's still in the storage tube new. " Guess if everyone took 20 minutes to pump out their tanks instead of 20 seconds with a 3" hose, we would need double the number of dump points to cope in busy times. |
Post Number: 122 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 14, 2010 - 11:41 pm: | |
I have seen people take much more than 20 minutes to clean up after the 3 inch hose fails or the bayonet breaks and they have a flood of very nasty solids all over the dump site. Just has to be a better, cleaner, more convenient way to deal with a nasty part of the lifestyle Les |
Post Number: 1091 Registered: 10-2004 Posted From: 75.201.54.135
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 15, 2010 - 4:26 pm: | |
I got my new/old disposal today so the fun begins WHEN I get a chance! |
Post Number: 123 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 15, 2010 - 4:52 pm: | |
Hey Ace Make sure you take lots of pictures of the building process and of the first time you dump your black water tank thru it. We are all rooting for you to hit a home run Les |
Post Number: 1092 Registered: 10-2004 Posted From: 75.201.54.135
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 15, 2010 - 10:59 pm: | |
Yea Les I will and I'm sure there ARE a lot of guys looking for a home run but not the kind your referring to!  |
Post Number: 1975 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 16, 2010 - 10:31 am: | |
For those of you that prefer the 3 inch hose for efficiency, go watch the movie RV with Robin Williams. Makes the macerator idea look pretty good. |
Post Number: 1096 Registered: 10-2004 Posted From: 99.205.78.210
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 18, 2010 - 1:58 pm: | |
Finally everything I need is in my hands. The hardest piece to find was the brass plate. Total spent to date, $15.00. Now the fun or mess one! |
Post Number: 109 Registered: 7-2004 Posted From: 75.91.204.52
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 18, 2010 - 4:06 pm: | |
Jeez, Ace, if you'da hollered, I'd have sent you some 1/4" brass plate! I have a sheet about 14"X16" I keep taking pieces off of. |
Post Number: 1979 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 18, 2010 - 9:28 pm: | |
I'd prefer to modify the ends of the garden hose/ disposer outlets to a different type of connection, so it could never be accidentally used for something else. Otherwise, it looks like a great idea. |
Post Number: 14 Registered: 10-2006 Posted From: 166.192.247.212
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 19, 2010 - 11:40 am: | |
Les I installed in 1997, live full time and have never had a problem. I used a 2 inch hose from discharge to tank , total length about 3 feet. Hose was bought at West Marine and looks like a high quality plastic hose with ribs in it. Prather |
Post Number: 129 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 19, 2010 - 2:45 pm: | |
I have found both a Jabsco macerator and a shurflo unit as well as a flojet. I have used both Jabsco and shurflo pumps for years and have had very good success with both. I won't use the flojet because of the set up. both the pumps I am considering have the same 11/2 inch suction side and 1 inch discharge. Our macerator toilet has arrived in Edmonton but I haven't picked it up yet. Thanks Prather happy bussing Les |
Post Number: 1222 Registered: 11-2005 Posted From: 173.202.29.139
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 19, 2010 - 6:18 pm: | |
I have a 12v portable macerator pump that hooks onto the 3" dump and will work fine through a 5/8" garden hose, although slow. Maybe a half hour to empty 100 gal. It calls for a 3/4 or 1" hose but try to find a 50' length one of those I can carry or afford. |
Post Number: 15 Registered: 10-2006 Posted From: 166.195.85.64
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 20, 2010 - 1:31 pm: | |
Les I actually looked at the hose today and it is only 1 1/2 inch ID. I put a coupler on the end by the tank in case it ever got stopped or or something, Prather |
Post Number: 1097 Registered: 10-2004 Posted From: 75.203.197.85
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 20, 2010 - 3:45 pm: | |
Sudden fatality...need to find another cheap garbage disposal for my home made macerator. Damn! I was close to finishing too! |
Post Number: 133 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 20, 2010 - 4:54 pm: | |
Just a minor set back. Keep plugging... er chugging |
Post Number: 1098 Registered: 10-2004 Posted From: 75.202.251.162
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 21, 2010 - 12:03 am: | |
Still looking thanks to a brand new set of drill bits that suddenly decided to take off and go thru metal like it was butter ruining a perfectly good armature! Dallas, now you know!  |
