mike leveck (Mikey89032)
Registered Member Username: Mikey89032
Post Number: 7 Registered: 10-2010 Posted From: 63.164.47.2
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 09, 2010 - 10:44 pm: | |
can anyone tell me where the turn signal light relays are located on a 68-4107? thanks, mike |
Post Number: 1012 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 6:51 am: | |
Mike I believe yours is in the compartment on your left. Read post above with rogers. Gomer |
Jim Wallin (Powderseeker01)
Post Number: 100 Registered: 10-2008 Posted From: 70.90.115.49
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 7:46 am: | |
On my 4107 it is in the "glove box" compartment to the right of the entry door, upper left hand corner looking in. |
Post Number: 1320 Registered: 10-2006 Posted From: 99.168.85.180
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 8:15 am: | |
Turn signal blinker relays come in a variety of AMP sizes. Be sure NOT to use a car unit if you have many larger lights. NAPA has HD flashers (truck + Skool bus)in their supply. FF |
Post Number: 8 Registered: 10-2010 Posted From: 96.26.148.188
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 1:12 pm: | |
Thanks alot guys, i was thinking it was in the dash somewhere. Mike |
Post Number: 1013 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 1:28 pm: | |
Mike I forgot to tell you waht a guy done to me about a flasher the was NOT working. Listen for the clicks and you will find it!!! DUH!! It don't work!! gomer |
Post Number: 9 Registered: 10-2010 Posted From: 70.173.26.251
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 4:58 pm: | |
haha, yeah right? i did find them though and found a loose screw on the relay for one of the wires. I tightened it and now they work again. Now i have to figure why my headlights are screwy. one inside and one outside headlamp come on. It should be both insides, correct? Or is it both outsides with low beam? |
Post Number: 1724 Registered: 12-2000 Posted From: 71.195.124.20
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 10, 2010 - 6:54 pm: | |
Mike - Outside lamps are low/hi beam combination. Inside lamps are hi beam only. Obviously, then, on low beam both outer lamps should be on. All four should be on in high beam mode. Use tell-tale on dash to differentiate which mode you're in. Break out the volt/ohm meter, it's time to do a little troubleshooting! FWIW & HTH. . . |
