brandon s owen (Brando) (208.251.255.26)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 24, 2003 - 9:39 pm: | |
what would cause my parking breaks to stick? how do you fix it? pd4107 gmc |
gabby (67.30.116.201)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 24, 2003 - 11:48 pm: | |
after you push the knob in to release the brake press on the brake pedal real hard. make sure that you have full 120 # of air |
Abajaba (12.217.206.141)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 25, 2003 - 12:14 am: | |
1. Release parking brake. 2. Make certain to have full air pressure on the bus. Press service brake pedal to the floor for three seconds. Do it in this order in case the brake system is old enough to cause parking and service brakes to add on top of each other. 3. Release the brake pedal and "bump" the bus with the clutch. If the bus rolls the brakes are released. If it does not roll the brakes are still applied. Try the three second application again and make certain that you have full air pressure on the system. 4. One possibility of a cause of sticking brakes is a roller that rides on the S cam being out of round. If it is on the flat spot and won't roll, then the brakes can lock up. I experienced this one myself on a tag axle of a model 102?3 MCI. It gets really messy when that there tag don't roll! Learned from it though. |
Ross Carlisle (Ross) (66.238.217.13)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 25, 2003 - 11:28 am: | |
You could also have an instance where the parking brake releases, but does not release all the way. Last fall when I brought the bus back from the tire shop, I released the brake and shifted to drive. The bus started to roll and everything felt normal. When I got home, the pax side drive wheel brake was smoking and the wheel was very hot. When I noticed that, I applied the parking brake, then released it as descibed in the previous post. Again, everything felt normal. I had someone press on the brake pedal while I looked at the brake arms through the hand holes and all looked normal. I have not driven the bus since, other than short little trips around the block to turn it around. So...How can you tell if the brakes are just dragging slightly. I don't know what kind of damage a dragging brake can cause. I'll now have to pull the rear wheels and inspect the brakes before I drive the bus....so I guess we'll find out. Ross |
