Stephen Fessenden (Sffess) (148.245.121.70)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 27, 2003 - 6:46 pm: | |
Thats right. 120 or 220 volts AC input and up to 300 Amps output. Spotted several in Mexico for $90 to $100 new. Must take a heck of a circuit breaker on 120 volts, but it exists. And I verified full output on 120 volts. No mistake. Posted in case any body has such a need. Hecho en Mexico. Big and heavy. |
two dogs (67.30.23.64)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 27, 2003 - 8:16 pm: | |
a.c./d.c.??? where in mex?? |
Jayjay (198.81.26.104)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 28, 2003 - 1:26 am: | |
Let's see...300amps is a 5/16 rod to weld 3/4" or thicker plate. Hell fellas, on 120VAC you'd burn the bearings out in your electric meter real quick. At 15 cents per KW, that's almost $20 bucks an hour to feed it!!!!! It would have to be on a fuse, since they don't make a 120V breaker that big. Probably pulls 120 to 150Amps at 120V. Whew, wait 'til you see a non-quartz filled fuse that big blow on a short. Goes like a stick of dynamite!!!!! ...JJ |
