4104 speedometer drive ratio Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » July 2003 » 4104 speedometer drive ratio « Previous Next »
Jim-Bob (205.188.208.39)
Posted on Tuesday, July 01, 2003 - 12:05 am:
Does anybody out there KNOW the speedometer drive ratio on a Spicer
manual trans in a 4104? (Expressed as __ x output shaft speed.) I
could not find the info in my 4104 book.
Jim-Bob
Posted on Tuesday, July 01, 2003 - 1:14 am:
Probably it isn't spec'd because the speedo drive ratio on most trannys is set up by what gear the tranny builder sticks in there, that gear is easily field-replacable by the end user, and there are as many choices as you can imagine. This is so vehicle manufacturers can match rear ends and speedos from A-Z without being stuck with one particular ratio.
The only way to tell is to actually count turns... or get an encoder and electronic speedo such as a VDO that sets itself up to whatever the ratio is, automatically, and not care what the ratio is...
Cheers
Gary
