Post Number: 142 Registered: 10-2004 Posted From: 98.216.83.122
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 04, 2010 - 7:40 pm: | |
Hey All, I am at the stage where I am going to cover the plywood walls with Naugahide.I need to fill some of the imperfections in the CDX with some kind of filler and than sand the serfice to make it reasonably smooth. I was thinking about Bondo or even maybe plaster.I am thinking one of you will have a better idea.thanks in advaance. |
Post Number: 1108 Registered: 10-2004 Posted From: 75.204.180.202
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 04, 2010 - 7:49 pm: | |
I personally wouldn't think about covering the plywood with Naugahide unless you put a cushion on the plywood first. It doesn't have to be a thick cushion. Just enough to cover up any imperfections such as seams and such. You can use the foam that is used under Pergo or laminate flooring. I used it with great result when I covered my ceiling. If your thinking about gluing it direct, you might find that ANY roughness, seams, splinters, knots, etc. will magnify thru the vinyl or any material for that matter. Evdn covering the plywood with wall paper needs special attention. We used a backer board on the plywood first. Actually we used door skin which is super smooth and then painted it with sizing! |
Post Number: 143 Registered: 10-2004 Posted From: 98.216.83.122
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 04, 2010 - 8:19 pm: | |
Ooh, the foam is a great idea, but I don't know what you mean by door skin.Did you glue the foam to the ceiling and then the Naugahide to the foam? |
Post Number: 1425 Registered: 7-2006 Posted From: 97.225.130.9
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 04, 2010 - 8:39 pm: | |
Or...the fabric shops sell a very nice, thin and CHEAP fiber stuff, very thin....that will (used in light quilting, I think, since my BETTER half was the one who suggested it.. )accomplish the same thing. We used it in MANY places through out the coach. FWIW RCB |
Post Number: 266 Registered: 2-2004 Posted From: 69.153.63.172
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 04, 2010 - 8:45 pm: | |
RCB has a good answer. Call some fabric supply houses and share what you are doing. That makes them very intrigued and they seem to get more helpful. They will sell you the substrate and glue that you need. With the right substrate between the naugahyde and plywood you may be able to forego the joint patching. David |
Post Number: 1046 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 04, 2010 - 8:52 pm: | |
carpet padding come 1/2and9/16 Thick. Scraps or left-overs work great and cheap too. Glue the foam on the board,then if you are putting anykind of material over it,you can glue it also to the foam. Tuck the edges and you have a rite down Purty job. LOL gomer |
Post Number: 1109 Registered: 10-2004 Posted From: 108.109.248.71
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 05, 2010 - 6:41 am: | |
Doug the door skin was only used on the parts of plywood that we covered with paper. When we covered with vinyl, like I said, I used a thin foam that is used under laminate flooring and glued it directly to the plywood. I then covered both pieces with the vinyl by stretching it slightly and stapleing it aling with using contact cement on the back side. My entire ceiling was done this way using individual panels that I could handle by myself. I used a process that has no screws and each panel can be removed for access. A little different than walls but it still can still be done the same way. I wouldnt use carpet pad. Too thick! |
Post Number: 1047 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 05, 2010 - 9:49 am: | |
Ace; We used the carpet padding because we kinda rolled and pleated the ceiling, However thinner padding does make for a thghter look and I AGREE wid ya?? Fix it so it may be removed if at all possible especially in those critical areas. Gomer |
Post Number: 616 Registered: 8-2004 Posted From: 70.60.102.61
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 05, 2010 - 9:58 am: | |
Thank you all for this info and sharing your experience -- it's very helpful to me in my stage of conversion. |
Post Number: 1110 Registered: 10-2004 Posted From: 108.109.248.71
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 05, 2010 - 10:34 am: | |
yeah gomer rolled and pleated and diamond tuck you would need a thicker pad |
Tom Christman (Tchristman)
Post Number: 262 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 05, 2010 - 11:26 am: | |
Problem with naugahide is that it is cold in winter and hot in the summer. I used thin indoor/outdoor gray carpet that has a nice feel to it on the walls, and is easily applied with spray contact cement (Dupont 90). My ceiling is paint gloss white with 2" wide oak strips to cover the joints. Simple, yet pleasing to the eye. Good Luck, TomC |
Post Number: 579 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 05, 2010 - 4:49 pm: | |
I used door skin and wallpaper |
Post Number: 205 Registered: 1-2009 Posted From: 69.171.161.62
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 06, 2010 - 2:30 am: | |
Ace- "yeah gomer rolled and pleated and diamond tuck you would need a thicker pad" My computer screen & keyboard did NOT need a fresh coat of coffee... ;) no- no, that's not what I meant to say, . . hmmmm What I really meant to say was.... Doug, you could hire Ace to come over and demonstrate MORE of his amazing sense of humor, while you drink something thick when facing the walls. 15 minutes of his expertise & the job ought to be finished, just use a really wide trowel & don't swallow. The guy's a barrel of laughs, this was the 2nd time I've spewed a screen on his account. ...well maybe not that either.. maybe I didn't have anything to say after all..? ....huh, . . . . wonder if THAT's ever happened on the Internet Tubes before...? mebee I should Google it and find out.... if I could only remember their address... . . . mebee MSN will know how to get there . . . . has anyone seen my pillow...? now I need more coffee...always something... . . . . I thought Nauga's were on the protected species list... maybe you're using Faux Naugahyde...? (Message eddittted by Jack Fids on November 06, 2010) (Message emditued by Jack Fids on November 06, 2010) (Message ebbatsmished by Jack Fids on November 06, 2010) (Message ebbaduded or sumthin by Jack Fids on November 06, 2010) (Message edited by Jack Fids on November 06, 2010) I'll bet you'll think I been a drinkin huh..?? Nope...not no mo ! But every once in a while on a Friday night, I like to re-live my past and act like I've been to the City and be stupid in public, it's faster & cheaper this way.... and SOMEONE will laugh at your stupidity..... . . . mebbee Ace & I can be a comedy sensation.... 2-Bus Guys or 2 times stupid is still just stupid . . . did ya know that 3 times stupid qualifies as a political party...? . . . (Message edited by Jack Fids on November 06, 2010) (Message edited by Jack Fids on November 06, 2010) ....and not only that... I VOTE...!!! makes you wonder.....eh? (Message edited by Jack Fids on November 06, 2010) |
Post Number: 1347 Registered: 10-2006 Posted From: 69.19.14.15
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 06, 2010 - 7:00 am: | |
PAINT ,, allows for EZ repair or touch up , and should some other color be desired , good paint is $30 a gallon, and a days work. I guess the coaches with expensive wall covering still have Harvest Gold and Avacado from the 70's. Do it your way! FF |
Post Number: 1115 Registered: 10-2004 Posted From: 108.118.5.112
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 06, 2010 - 8:06 am: | |
Fred, you guessed wrong as usual. Besides, the general public (converter) would like something easy to clean and not have that paint smell. Show me a high end coach with harvest gold, avocado colors and painted walls! Well I know your decor is similar but I DID say high end coach didn't I! |
steve wardwell (Steve_wardwell)
Registered Member Username: Steve_wardwell
Post Number: 108 Registered: 2-2010 Posted From: 75.204.254.112
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 06, 2010 - 10:45 am: | |
use the 1/4 foam under vinyl for soft look... apply glue with a roller then foam... ditto then the vinyl the spray glues won't hold well on the walls |
Post Number: 1348 Registered: 10-2006 Posted From: 69.19.14.40
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 6:19 am: | |
"Besides, the general public (converter) would like something easy to clean and not have that paint smell. " Guess you found the non stinking way to get fried grease our of your wall rug covering ? Or you just eat at the Salvation Army and don't have to clean up? OIL paint smells when being applied , the newer crappy water paint smells very little . Our choice is the Stock 4106 overhead , cleans up to almost new with a sponge and some "Bartenders Friend". The difference is the same as always , a coach to Cruise and live in , or one to park , stand next to and hope for acceptance. How do the "PrevOst Prouds" like your back yard beauty? FF |
Post Number: 1116 Registered: 10-2004 Posted From: 108.118.5.112
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 6:56 am: | |
"Guess you found the non stinking way to get fried grease our of your wall rug covering ? Or you just eat at the Salvation Army and don't have to clean up? " Freddie, I tell you, when will you ever learn, I DON'T have "wall rugs" and we DO eat in our coach without the lingering odors your accustom to. "OIL paint smells when being applied , the newer crappy water paint smells very little ." Again Freddie, I was commemting on your previous post about you using GOOD 30 dollar oil paint ver. that crappy water paint. I actually didn't know Krylon came as an oil paint in a rattle can. We all know that's what YOU used since your too cheap to use the GOOD stuff! "The difference is the same as always , a coach to Cruise and live in , or one to park , stand next to and hope for acceptance." I have no problem being "accepted" anywhere! Bet you could say the same about yourself and your relic! How do the "PrevOst Prouds" like your back yard beauty?" I wouldn't know to be honest. Never joined nor do I have any desire to! You better go dig for better fuel because you seem to be slippin! You HAVE to be getting old! You still taking your meds? |
Post Number: 1349 Registered: 10-2006 Posted From: 69.19.14.40
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 7:39 am: | |
"I wouldn't know to be honest. Never joined nor do I have any desire to!" HMM, I remember years ago when you first got your rolling contraption , I thought you went to a select Prevosttt gathering? Must have fantasized that it was moving on its own power! Don't worry , Jacks is only a few miles from your place , the tow guys wont mind.You can wander about cursing Christmas greetings as always. After a few weeks of quiet the old ankle biting ACE OF HATE broke thru again. Sad as always,but hardly unexpected. FF |
Phil Smith (Phil_smith)
Registered Member Username: Phil_smith
Post Number: 55 Registered: 3-2006 Posted From: 24.116.71.31
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 8:14 am: | |
Doug I used commercial grade wall paper. It's thicker and more durable than the household stuff. Anyway back to your 'wall' question.. I used CDX on for my walls- then trowelled some wood filler(the thinner stuff that's white colored and is used for wallpaper prep) into the 'voids' of the CDX. It's real fast and easy. Sand when dry - then apply the covering of choice. The filler adheres nicely to the CDX and the 'covering adhesive' adheres nicely to the filler. The commercial grade wall covering is thicker and sort-of a vinyl-cloth stuff and is more forgiving of little imperfections.. Your choice of wall covering should be just fine if it has some 'body' to it. Just my way . |
Post Number: 1117 Registered: 10-2004 Posted From: 75.202.183.127
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 8:31 am: | |
Sounds like the pot calling the kettle black to me pal! Talk about a rolling contraption? Uhh have you really looked at the relic you drive compared to what is REALLY a conversion? I mean REALLY Fred, who ARE you kidding, but it doesn't hurt to dream I guess! Keep dreaming Freddie! Last time I looked or drove it, Jack's rally was about an hour and a half from MY place so as always, your mind went blank you spoke words of ignorance and WHO other than yourself cursed Christmas cheer? Still wondering how your relic, of what you refer to as a sports car, carries all that coal you have acquired over the years. If I were you, I think I would try and make friends with Santa. Heck he's about the ONLY guy left that you might possibly call a friend! And Freddie, Hate is a pretty strong word! Don't even think for a moment that I actually hate you! In fact, you would be glad to know, I love you bud! I love everything you do, you say, and your good looks! Heck I could even grow to love your relic! It IS a bus, at least it used to be and this IS a bus board! So, share the love! xxxooo ROFLMAO |
Post Number: 1118 Registered: 10-2004 Posted From: 75.202.183.127
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 8:33 am: | |
Post Number: 968 Registered: 8-2006 Posted From: 74.33.49.149
Rating:  Votes: 2 (Vote!) | Posted on Monday, November 08, 2010 - 1:08 pm: | |
The love for each other you 2 show just brings tears to my eyes lol |
Post Number: 210 Registered: 1-2009 Posted From: 69.171.161.16
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 2:11 pm: | |
whatever.... when this little fire flares up, I only benefit, it takes other members minds away from questioning MY sanity... whatever THAT is! My own actual first experience with a Prevost... Intrigued by it's size & contemporary design & drawn by the "OPEN" sign, I stroll towards the open & inviting door. At the exact moment my left foot was making contact with the 2nd step, I was advised that visitors leaving fingerprints on any surface would be asked to leave. I executed an immediate military 180 & was then asked why I was leaving! I explained that my reputation was at stake by my mere proximity to someone who's standards are so low that they would allow common wage earners into their coach. You just have to develop the skills necessary to engage with people of different strata's, speak their language & mimic their behaviors to communicate with them effectively & at their level.... then you'll reach understanding! . . . See, all that money I spent at that Doug Carnegie course wasn't a waste after all...! . . . Photo of secret Prevost Owners meeting....
(Message edited by Jack Fids on November 08, 2010) |
Post Number: 1119 Registered: 10-2004 Posted From: 108.118.5.112
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 3:15 pm: | |
Jack be advised that the name prevost is just that, a name, not a status as you might think. My prevost is just another bus and your welcome to lay your grimy fingerprints anywhere you wish! At least I welcome you to do so just as I have everyone else I have met. Now, that's more than I can say for some people and their sportscars... right Freddie? Nice pic by the way! Must have been a prevost prouds meeting! LOL |
Post Number: 969 Registered: 8-2006 Posted From: 74.33.49.149
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 3:23 pm: | |
I think you guys got your Prevost groups mixed up here.I belonged to the proud for years I never met those guys maybe the POG |
Post Number: 211 Registered: 1-2009 Posted From: 69.171.161.16
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 4:36 pm: | |
Ace...when I saw my 1st 4106 conversion at the Greenville Ohio FMCA get together back in 1964(?), I thought to myself then....".is there NO END to the lengths that people will go to in impressing people they don't know? How "Over the TOP" can some people get?"... See how I have eaten those words today....a deck on top of my own 4106.....my how I have lowered my former lofty ideals eh? My FIRM position is this.... if you are crazy enough to embrace a bus as a means of trying to enjoy life...you have ALL of my pathetic & sympathetic respect! And you Sir, are no exception! I just enjoy wielding a sharp stick occasionally, my diminutive size requires that I over respond in order to retain self-respect. Even tho it appears small people sleep, actually we are just plotting against larger people with our eyes closed. ;) notice the one eye closed?...I'm thinking about YOU! (Message edited by Jack Fids on November 08, 2010) |
Post Number: 1056 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 5:18 pm: | |
Jack, Jack, Where is Chessie when ya need him? LOL Now boys ya'll behave now! Sound familiar? Welcome to the WONDERFUL world of bus-NUTS gomer |
Post Number: 1996 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 8:07 pm: | |
One good thing with painted walls and original ceiling. You can clean the inside with a pressure washer. Everyone does what suits them; why some even leave their baggage racks in.Do it my way, your way,everyone else's way...whatever. |
Post Number: 1058 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 08, 2010 - 8:37 pm: | |
Chessie!!! Thar ya go agin!! Gomer |
Post Number: 1350 Registered: 10-2006 Posted From: 66.82.9.99
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 7:22 am: | |
I'm not sure with a wooden floor a water Pressure washer would be bright , but the Overhead Racks? They sure do make it easy to load and unload to go cruising. Of course the concept of what the bus is for , cruising a couple of months a year , or home on the road , are similar but not identical. A bus camper is all about PM , keeping a high end commercial vehicle in really safe roadworthy shape. Weather one is comfortable with a simple interior , or "needs" a home copy of a Pro conversion , is a "MY WAY" decision. The early starting days of the FMCA , a top of the line conversion was usually a GM Silversides , with dark shag rug glued to most everything. Some folks still do this as "retro", tastes vary. FF |
Bill 340 (Bill_340)
Registered Member Username: Bill_340
Post Number: 122 Registered: 7-2006 Posted From: 75.202.226.139
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 7:48 am: | |
You know, with todays economy and jobless rates, its nice to see some humor, NONE of us I hope really think Ace or Fred really hate each other.They actually enjoy the bantering, sort of a fun way to let off the daily pressures. Just last week Ace was answering one of FF questions,Without any snide remarks,Just sit back and enjoy the ride, Cause they are both right, as usual, Both individual opinions. That dont agree, Sounds something like marriage....OOPS |
Post Number: 1061 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 8:16 am: | |
Bill I think that they have a pact to agree to disagree so we can spueeee coffee all over our computors LOL Gomer |
Post Number: 1120 Registered: 10-2004 Posted From: 75.202.153.30
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 3:23 pm: | |
Gomer... I would have to agree!  |
Post Number: 518 Registered: 10-2004 Posted From: 173.77.223.202
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 9:33 pm: | |
Fred is not past one-upsmanship! I thought i was the cats bow-wow with my bycycle on a rack in the back and Fred has to show up with a buycycle built for two ON THE FRONT of his rig! This year i might have to go to a trycycle on the roof. how about an update post on the new flex and repower? Cant wait to get to Arcadia. |
Post Number: 1064 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 9:47 pm: | |
Maybe we need to get the route Fred is taking and Oh well just a thought LOL gomer |
Bill 340 (Bill_340)
Post Number: 123 Registered: 7-2006 Posted From: 75.216.123.179
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 8:24 am: | |
Guys Fred is Fred nothing wrong with his veiws, because they are His, yours are yours and mine are MY WIFES. Most of you all know this is their fun, sometimes it gets a little nasty, Why Because we all have feelings, I know most of us know the truth. just typing so the NEWBIES understand, And Dave I think the three wheeler would look nice on your bus, I think you should use your efforts, to put a sign on your bus so we know which is the front and which is the back........... |
Post Number: 1065 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 9:30 am: | |
Bill; I think that if we didn't have the busnut family we have here, it would be non-informative not only to us ,but the newbies as well. I think for the most part, when one of us gets a problem, we all will junp in and try to help. Then the fun begins LOL Right Fred and Ace?? I think that this board will solve ANY BUSNUTS problem and still have fun at being huh stupid is not a word here, Overlooking something is more appropreiate[spell check] lol. I think that whatever you want to do with your coach is just fine and that's the truth!! gomer |
Post Number: 219 Registered: 1-2009 Posted From: 69.171.161.161
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 1:55 pm: | |
"I think that whatever you want to do with your coach is just fine and that's the truth!! " Just as long as you stay behind me on the road and don't expect to park in my yard.. you transit types that assume you have a real bus just crack me up! . . . . ;) |
Bill 340 (Bill_340)
Post Number: 124 Registered: 7-2006 Posted From: 75.216.123.179
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 3:26 pm: | |
It's been said, "You don't stop laughing when you die, you die when you stop laughing!!" |
Post Number: 225 Registered: 1-2009 Posted From: 69.171.161.161
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 4:35 pm: | |
Truer words have never been posted on the InterNet Tubes Bill, an ill-literational entendre of that is.... By keeping it light, life never becomes heavy. Bill, you have just proven that by associating with fools you can appear to look like a genius! We know our roles well! Speaking for myself...being at the bottom of the pile, the warmth from those above me keeps me alive. |
Bill 340 (Bill_340)
Post Number: 125 Registered: 7-2006 Posted From: 75.216.123.179
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 4:46 pm: | |
Doug,..........BY the way did you ever figure out what to do with your walls? |
Bill Holstein (Billmoocow)
Post Number: 132 Registered: 5-2009 Posted From: 71.59.162.64
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 11:41 pm: | |
Hmm. I did not see this post. Now I am sad. This turned into money v.s. ingenuity. You both have cool buses, nobody should put anyone else down. No matter what their bus is. Fred has a bus i want and Ace has a bus i want. No winner. Never. |
Post Number: 1998 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 11, 2010 - 10:19 am: | |
Fred, why would he want to paint the Naugahyde on his walls? |
Post Number: 233 Registered: 1-2009 Posted From: 69.171.161.151
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 12, 2010 - 3:23 pm: | |
Bill Moo.... Ingenuity IS what it is all about in doing a conversion... money is just the plan B to save a butt when the ingenuity runs dry. IMHO I assume that each and EVERY "put-down" is actually either just veiled envy or good natured ribbin born of obvious difference & circumstance. Not for one minute do I believe that anything posted here is intended to be hurtful or disparaging. We are all pots & kettles and calling one black only points to our similarities & camaraderie.....of collective folly! Stan Laurel put it the best... "He who filters my good name, steals trash!" I can do that one better tho.... "He who steals my bus is driving garbage..." because everything in & on my bus came from the boneyard or was a cast-off. It's ALL in the eye of the perceptionist. . . . beside that, what in the heck does ANYONE named BILL know..? |
Post Number: 1357 Registered: 10-2006 Posted From: 66.82.9.99
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2010 - 6:22 am: | |
Fred, why would he want to paint the Naugahyde on his walls? Because he is tired of the color? The choice that was made , to use CDX ,( flooring materials ), instead of that really fine Canadian Birch plywood is probably the reason he is covering over instead of painting.Although some folks feel covered ply is quieter as the covering may absorb some road noise. Coach conversion is lots of choices, ALL of which have real outcomes , down the road. First cost and total cost are frequently very different.Desirements vary, FF |
Van (Van)
Registered Member Username: Van
Post Number: 122 Registered: 7-2008 Posted From: 68.108.81.25
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2010 - 9:44 am: | |
LOL! Any one for contact paper? I think I'll paint mine today hmmmm. (Message edited by van on November 15, 2010) |
Dallas Farnworth (Dallas)
Post Number: 140 Registered: 7-2004 Posted From: 75.91.207.143
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2010 - 1:31 pm: | |
What about neon orange/green/purple long shag carpet for the walls and ceiling? |
Post Number: 1125 Registered: 10-2004 Posted From: 108.108.222.20
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2010 - 2:58 pm: | |
Now Vam and Dallas, if you both convince more people to use those techniques, you take the chance of FF getting upset. You DO know that he still uses those colors and copying his coach is a definite no no. Besides. The best way to cover your walls is not to. That's right! Leave them just as they were. Now if you happen to have a neighbor that is throwing out old carpet or cabinets or bed sheets, dive right in and snatch them up. That's legal in Freddie's world and whatever you do, DON'T cover over the windows. FF is the only person I heard of that had a clear plastic pup tent when he went camping as a child. He's far from being modest. I mean, think about it. Why should he be? :o |
Post Number: 1073 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2010 - 7:47 pm: | |
CHESSIE!! You better get ready to ref-a-ree>> LOL Ace gomer |
Post Number: 1358 Registered: 10-2006 Posted From: 66.82.9.62
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2010 - 6:36 am: | |
"copying his coach is a definite no no Not by me, So far my instructions posted for installing a truck door lock in the coach front door, and the concept of creating a double use for the shower area , by a 3 track sliding hanging locker seem to still be in use. Reinventing the wheel is a waste of life , so most folks enjoy useful concepts. Ever had an origional thought in your life? Or just BS and more ignorant HATE , HATE HATE? FF |
Post Number: 1126 Registered: 10-2004 Posted From: 173.6.43.29
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2010 - 7:43 am: | |
Freddie, when will you learn, I don't hate you! I love you man! Your just a toy. Something to play with! As for an original thought? Uhh yea, but that would only make you think I Really do hate you and thats not the case! And Freddie, the concept of taking a dump, showering and shaving out of the same 5 gallon bucket has long been replaced. Hey people actualy use plumbing in their buses now. ROFLMAO |
Post Number: 1075 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2010 - 2:37 pm: | |
CHESSIE !!! Better still IAN Help!! LOL Gomer |
Post Number: 2005 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2010 - 7:05 pm: | |
Basically we are talking about two different concepts... a bus that has been converted into a home and a bus that some one just lives in. Both work; just different concepts. A bathroom and job johnee both serve the same basic service, just the comfort level is different. |
Post Number: 1359 Registered: 10-2006 Posted From: 69.19.14.32
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2010 - 6:46 am: | |
I don't hate you! I love you man! Your just a toy. Something to play with! HMMMM, Last time I went to visit at Jacks get together , to find great goodies at the flea market (got a fine co pilots seat)I was talking to the nice folks that create front window covers. You drove up on a electric golf cart , looking to scrounge something for your bus camper , so I said good by to the nice folks. Your first and only words were "Good Riddance", guess that's your normal Christmas greeting. HATE or Love , George Orwell , are you watching? FF |
Post Number: 1127 Registered: 10-2004 Posted From: 108.118.146.55
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2010 - 8:22 am: | |
Uhh Freddie, those nice folks are my best friends ans neighbors. I visit with them and do dinner often and it was me that drove up as you say and only said good riddence AFTER saying "hello Fred" and you looked me square un the face and didn't say a word but rather walked away! Sort if like "kiss my ass" so yea with that attutude, good riddence! And just a note, I don't "scrounge" things up for my bus. That would be next best thing to dumpster diving and we all know your the king of that! |
Post Number: 1360 Registered: 10-2006 Posted From: 66.82.9.55
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2010 - 3:01 pm: | |
All this fun is great , but just remember ACE of HATE has never ever seen the inside of my bus. A decade ago he "heard" from a friend, of a friend or something , and has been posting his ignorance since. I wouldn't bother to give him a tour as he certainly would not understand custom cabinets . The the concept "Empty Bays" is the way I prefer to use the interior volume though it doesn't look "fancy" enough to a Status Freak that posts himself by his shells name . The modified ( not removed)overhead baggage areas would be beyond his understanding. The real fun will come when he discovers the next project (2 years so far) is a 1956 35 ft coach , not a big shoebox. That should pop his head! FF |
Post Number: 1076 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2010 - 4:37 pm: | |
Guys!!! We all have our opinion on everything. No when it comes to Our COACHES it is the same. Some like purple,some like green[lime] other may not even have a color cordinated look,but does matter?? I enjoy good times and laughter more that most folks and love to be around people that enjoy life. I wasn't promised a tomorrow but by HIS grace I was promised eternal life. Now our job is to spread GOOD WILL and PEACE among our friends. So how can we do that if we continually hit on each other. I believe we lost[?] a bus nut because of contraversy here. AS chessie would say and I agree CHILL OUT and love your friends.YOU may need them someday LOL gomer |
Post Number: 1128 Registered: 10-2004 Posted From: 69.96.28.239
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2010 - 4:44 pm: | |
Damn Gomer, if I loved ole' Freddie any more he would have to leave his wife and I would have to take him in! I can only spread so much love you know! |
Post Number: 1077 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2010 - 4:58 pm: | |
One Down!! Another to go LOL Gomer |
