Greg Roberts (Gregeagle20) (24.175.223.137)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 21, 2003 - 8:12 pm: | |
Is anyone using wind generators for auxillary power? I am weighing wind against solar and my primary purpose is to keep the batteries properly charged while the bus waits for my next trip. |
Doug (68.83.22.146)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 21, 2003 - 8:30 pm: | |
I have two smaller solar pannels......batteries have nevery held up better Doug |
Earl-8-Ky (207.162.163.19)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 21, 2003 - 10:34 pm: | |
I use a marine 10 amp charger that goes to a float charge when the batts are charged. I have 6 12 volt gell cell and I like them. Never have to worry about water. |
Doug (68.83.22.146)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 22, 2003 - 6:51 am: | |
Charger is great but if you don't have shore power available then I would go with solar.......From my assumptions......chances are you will get more continuos sun power than enough wind power unless you live in Tehachappi CA or similar place with a constant wind source |
CaSteve (208.19.55.88)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 22, 2003 - 1:16 pm: | |
The only one I have seen for rv use was while camping on the central Cal coast, there was one temporarilly mounted on a neighboring unit. The propeller was so loud it was annoying, and not too many things annoy me. You stated the purpose was to keep a surface charge while at home, so you don't have to worry 'bout the campground disturbance, but be preparred for a comment from momma at home. My suggestion would be to see one in operation before biting the bullet. In all fairness, the one I saw(heard) could have been homemade using the wrong propeller. Good luck, Steve |
