thomas flocks (Taflocks)
Post Number: 390 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 11:28 am: | |
the antifreze level on a 4106? |
Bob MacIsaac (Wildbob24)
Post Number: 117 Registered: 5-2007 Posted From: 98.92.174.208
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 3:02 pm: | |
You can open the filler cap and look in the surge tank. The "book" method is to open the level valve, if fluid flows, you're OK, if not, add coolant. |
Post Number: 1733 Registered: 12-2000 Posted From: 71.195.124.20
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 09, 2010 - 8:24 pm: | |
Thomas - The surge tank access is located behind the air intake grill on the driver's side rear corner of the coach. That grill is actually a door, pull on the RH side of it as you're facing the coach and it should open. If the level's correct, you should be able to feel it just below the fill spout when you insert a finger. (Do it cold!) Any more than that and the coach will spit it out the overflow as it comes up to operating temp. FWIW & HTH. . .
Post Number: 391 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 6:15 am: | |
i know where to check just not the proper level as you cant see where the fluid is. also how hot should it be during use? the most i have ever seen is 150 degrees. |
Post Number: 1354 Registered: 10-2006 Posted From: 66.82.9.15
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 6:22 am: | |
In normal operation just below or at 180F is normal. Could be no thermostat or crappy instruments or a poor instrument ground. What does the oil pressure read , same ground? A heat reading gun , will tell if its the instrument , or some PO forgot the thermostat. FF |
Post Number: 392 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 10, 2010 - 6:49 am: | |
oil is 60 lbs |
