Jayjay (198.81.26.104)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 07, 2003 - 12:05 am: | |
Cerro Wire and Cable is the manufacturer, Vinylon-u, is a trade name for the propritary thermo-plastic insulation, 4/0 is the AWG Size (American Wire Guage) Look for another set of specifications such as: THHN, THWN, MTW, FEP, etc. Also a temperature range i.e. 75 C., 90C., or 105 C. If it is only listed as Type US or USE, you can't use it. 4/0 may be big enough, depending on the number and type of battery you buy. You will probably be happier with Type SOW or SJOW welding cable. Get back to me at jarjaje@wmconnect.com for more off-line help. Cheers...JJ |
