Francis Dale Leyten (Fdale) (199.247.228.240)
Rating:  Votes: 1 (Vote!) | Posted on Tuesday, December 19, 2000 - 7:16 pm: | |
Oh Boy!! Another New Board! Many thanks 2 all. I have just received new hinge material for my MCI5 I will be installing in spring - not now as was -44 Saturday nite!! I do not want to use any petroleum-based lubricant to install, as I am afraid of rubber being harmed by it. what have other bus-nuts found to be the best way and/or lube to install these. Thanks in advance. Dale |
Douglas Lemmon (Toolman) (207.44.55.132)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 19, 2000 - 8:41 pm: | |
A little bit of talc (aka: baby powder) goes a long way for helping rubber to slip into place without being harmed. Good luck & Happy Holiday's Toolman |
bubbabusnut (216.80.138.159)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 19, 2000 - 11:39 pm: | |
I find that wire lube works well and easily washed off when done. Wire lube is what electricans use to pull wire through conduit. also its harmless to rubber. |
Mike SS (24.234.180.164)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 20, 2000 - 12:48 am: | |
Good old K Y jelly It is water based and washes off easy. Forgive the pun it won't hurt the rubber. Mike SS |
Mike 4905 (207.190.10.214)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 20, 2000 - 7:25 am: | |
I was told to use waterless hand cleaner like go jo. I used it on mine and it worked perfect. Mike |
Tuck-04 (207.144.133.155)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 21, 2000 - 4:26 pm: | |
Its real easy and simple...Get you a spray bottle and put some dishwashing detergent in it and add some water and spray it on the rubber and in the track..I used it and it worked real good. Tuck-04 |
bubbabusnut (216.80.138.61)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 22, 2000 - 5:58 am: | |
another hint, on my 4106 the track needed cleaning out. tried all sorts of stuff. used the brass (or copper) wire brush I got at the gun show to scrub mygun bore. Has about 8 or 10 inch twisted wire shank with a loop on the end. cut off the loop with your dykes then use your drill to run it through the track. 45 cal. is the size of my 4106 |
Gil Hegel (209.250.9.75)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 22, 2000 - 9:11 pm: | |
Wire lube for me too $5.00 at home Base lasts a lifetime...... If in Mesa AZ use some of mine.. Best of luck... Gil |
california bob (199.174.223.204)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 27, 2000 - 10:37 pm: | |
Armoral works too! |
Al Newell (206.215.84.70)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 01, 2001 - 12:09 pm: | |
Do not use talcs. They all have a perfume which is bad for the rubber. Corn startch will do the same thing without harm. Very old wetsuit trick in days of SCUBA way back when. |
