Post Number: 1174 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 10, 2011 - 6:34 pm: | |
Need to figure cost verses replacement. 1982 eagle rear brake chambers, Dreive wheels. Need info on relace diaphrams or buy complete units.??? gomer |
Post Number: 282 Registered: 7-2004 Posted From: 75.91.197.33
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 10, 2011 - 7:09 pm: | |
DD3's? $500/each Replace diaphragms? a couple hundred for both sides. Spring Brakes? under $200 for two new cans. Spring Break? .......... Priceless! |
Post Number: 1175 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 10, 2011 - 7:41 pm: | |
thank you Dallas. The unit is not DD3 as I thought and when you fire the bus up it took a while to reach pressure and then when you hit the brakes it would drop about 20# quick and finally found the culprit and pulled the wheels and there it was, covered with a little dirt and finally got it off and checked it.... BAD!! I will go to my supplier tomorrow and see if they have a couple in stock and replace both while I be under there LOL gomer |
Post Number: 1002 Registered: 8-2006 Posted From: 74.33.43.204
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 10, 2011 - 8:05 pm: | |
Eagles model 10 were springs 30/30 good luck |
Post Number: 576 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 11, 2011 - 8:33 pm: | |
Don't know if they all are this way but my Eagle has an air valve that makes the brakes function like DD3s. You have to do a full pressure application to unlock them after parking. But they are actually spring brakes. Last spring brake cans I bought about 5 years ago were $35 bucks each! No core charge. |
Post Number: 1177 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 11, 2011 - 9:42 pm: | |
Got em! $50 bucks each,2studs,2inner nuts,2outer nuts, 3 hours back on the ground adusted and ready to go. will replace the other side when it warms up some more. lows 22 high50 until sat then 65 highs. OH no core charges either as they are made in CHINA and are non repairable!! Imagine that? For your info the studs are getting scarce, mine were euclid #9002. gomer |
