Iver (Mciv)
Registered Member Username: Mciv
Post Number: 38 Registered: 11-2006 Posted From: 70.69.131.252
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 14, 2011 - 3:56 am: | |
Does anyone the "simple version" of connecting a 12v Stone Bennett shifter in a 24v system? Thanks to Clifford I have enough of a manual to get all the mechanical connections hooked up and some of the electrical. I am making my own control with a toggle switch and a series of led indicator lights as I have seen others do. I understand when the shift actuator moves up or down, it grounds the various led's to show what gear has been selected. I was going to run an 8 wire 20ga signal cable for the led lights. I would like to control the shifter through the ignition so it works when the ignition is on. But the ignition is 24v. I also wanted to have the ignition operate only when the shifter is in neutral. I can run 12v for the shifter solenoid right from the control. If so, what size of wire?(@50ft). Or I can use relays in the engine compartment and take 12v from there. Then what size of wire for the 50ft. Any help would be appreciated. Thanks, Iver. |
Bill Gerrie (Bill_gerrie)
Post Number: 409 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 14, 2011 - 10:14 am: | |
Iver Go to my profile and call me. Give your phone number and I will call you. There is too much to explain here. Especially the neutral shutdown. Bill |
Iver (Mciv)
Post Number: 39 Registered: 11-2006 Posted From: 70.69.131.252
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 14, 2011 - 11:52 pm: | |
Hi Bill, Thanks for the kind offer of help. I will try to get some time shortly and will certainly give you a call. What would be very helpful to me, (sometimes slow to understand), is a rudimentary sketch of the wires and their connections. I do have some instructions and drawings, but nothing showing the details I need especially when dealing with the 12v and 24v systems. Thanks, Iver. Abbotsford, B.C. |
