Steve "Spanky" Aune (Spanky77707)
Registered Member Username: Spanky77707
Post Number: 36 Registered: 1-2010 Posted From: 69.59.100.44
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 10:42 am: | |
I'm still remodeling my interior, coming along good, except, what can I use to cover my rear ceiling with the curves. Nothing I've found bends that much? |
Post Number: 293 Registered: 7-2004 Posted From: 75.91.197.33
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 11:06 am: | |
Bendy board, Formica, Cardboard, plywood with multiple half inch kerfs cut in the back.... Or build the curve out in multiple square edges, then use the tunnels left by the squares to make wiring chases. Where there's a will there's a way! |
Post Number: 1007 Registered: 8-2006 Posted From: 74.33.43.204
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 11:49 am: | |
Luan covered in whatever headliner material you choose. From the photo looks like a Eagle cap so cut the luan to make that curve about 16inches I think then butt the other to that and you are on your way good luck (Message edited by luvrbus on January 16, 2011) (Message edited by luvrbus on January 16, 2011) |
Cory hart (Chart1)
Post Number: 46 Registered: 1-2010 Posted From: 12.97.138.130
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 12:24 pm: | |
if you dont round it and put a piece from the flat of the roof to the flat of the wall it will leave you a tunnel all the way down the length to run wiring |
Greg Smith (Pawsbus)
Registered Member Username: Pawsbus
Post Number: 20 Registered: 10-2006 Posted From: 24.109.126.128
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 12:45 pm: | |
I used corroplast for my ceiling. 4x8 sheets, corrugated plastic, lite weight, non staining and easy to clean. |
Post Number: 1165 Registered: 10-2004 Posted From: 173.136.145.214
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 3:10 pm: | |
Sometimes you have to think outside of the box so to speak. Since I opted to use rounded corners everywhere I possibly could, to save on chips on the laminate, I also rounded those roof corners as well. Instead of following the contour of the curve, I rounded it outward to match the rest of my cornets. This allowed for some pretty keen wire chases as well and it was easier! |
Post Number: 37 Registered: 1-2010 Posted From: 64.234.16.147
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 4:33 pm: | |
thanks everybody, I'll try nd see which works best for me...Spanky |
Bob Glines (Robertglines1)
Post Number: 5 Registered: 11-2010 Posted From: 75.207.120.142
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 17, 2011 - 9:43 am: | |
Flex plywood called wiggle board 3/8 used in construction to make forms for concrete with radius or circle. I used on Mci 8 for ceiling. Ck lumber yards not HD or Lowe's Bob |
Post Number: 273 Registered: 2-2004 Posted From: 66.142.67.2
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 17, 2011 - 2:36 pm: | |
I'm with Cory's idea on this. It is nearly impossible to make all those compound curves look good. Try making stuff as flat as you can with furring strips or iron, etc. and cover that up. David |
Post Number: 38 Registered: 1-2010 Posted From: 64.234.16.147
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 17, 2011 - 10:04 pm: | |
thanks again...Spanky |
Post Number: 712 Registered: 5-2007 Posted From: 64.40.213.45
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 19, 2011 - 1:35 pm: | |
Spanky, When I did the rear of ours I put up some furring strips and did not follow the exact curve, smoothed it out some. I attached the strips to the steel frame for the rear cap. Then added 1/4" plywood over and then 1/4" oak plywood. If I were to do it over I would square everything up and use the interior space for wiring or whatever. It was a real pain, but it sure does look nice! |
