latvia-69 (Latvia69)
Registered Member Username: Latvia69
Post Number: 1 Registered: 1-2011 Posted From: 74.235.203.176
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2011 - 7:05 pm: | |
glued on aluminum panels with sikaflex and would like some opinions on what to use as a filler between panels. must be able to paint over filler. is butyl rubber any good? |
Post Number: 274 Registered: 2-2004 Posted From: 69.153.74.99
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2011 - 10:33 pm: | |
I saw an Eagle at the Brownsville rally back on 2007 with glued siding and wow it looked good. Sikaflex was the glue of choice. I think the guy was from Michigan but can't remember. I'm not sure what you mean about "filler". David |
Dave Walker (Chrome_dome)
Post Number: 184 Registered: 3-2010 Posted From: 67.174.144.159
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2011 - 10:58 pm: | |
If exposed to the air Home Depot "5200" Paint-able, seals fittings and seams on Boats even under water. Will cure in about 7 days completely so any overage make sure you clean off before that. Dave |
Post Number: 388 Registered: 1-2009 Posted From: 72.211.128.245
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 02, 2011 - 2:22 pm: | |
By the way you have stated your "problem" you lead a person to believe that your panels were "Butt-Joined" rather than the more traditional "Over-lapped" method of application.... thus you have joints where there were none previously.... and I think that is where the confusion lies with anyone reading & desiring to help or advise... Is my assumption correct? |
Post Number: 2 Registered: 1-2011 Posted From: 74.235.203.72
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 02, 2011 - 6:38 pm: | |
aluminum panels are blank out panels for windows. i have a bus just like the one on the home page of this web site. there is a space between the windows i want to fill in just in case i didn,t seal it perfectly with the sika. sorry about the confusion i forgot to mention windows. i have blanked out three a side 4 windows 3 blanks 2 windows going front to rear. thanks |
Post Number: 391 Registered: 1-2009 Posted From: 72.211.128.245
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 02, 2011 - 6:55 pm: | |
Ah Ha..! Now I see and you won't! I would consider filling from behind to keep the mating line clean. Beyond that I can only advise from experience not to use Sika flex or Silicone sealer...also add sanding/filler red putty. AFTER I did mine, I wished that I had used a vinyl "door edge guard strip" around the perimeter w/the joint at the bottom middle, to fill the gap cleanly, I expect the life expectancy wouldn't be more than 4-5 years tho. |
