Steven Foster (57_gmc)
Registered Member Username: 57_gmc
Post Number: 24 Registered: 12-2010 Posted From: 72.156.216.251
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 04, 2011 - 7:05 am: | |
After reading the 58 hits on the other thread. We have put my radiator in the cleaning tank and I forgot to take the Shroud off, and guess what when the tank came out there is not a sign of a shroud on it !!! Anyone might help me locate one before I have to start fabing one up ?? This is in my 57 GM 4104. If it does not warm up in Tenn. I want need one. LOL |
Brandon Merritt (Brando4905)
Registered Member Username: Brando4905
Post Number: 33 Registered: 3-2009 Posted From: 74.97.206.161
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 04, 2011 - 8:57 am: | |
Steven, Finally, I thread about buses!! Might be a little far for you, but check with Cardinal Coach in Warsaw,NC http://www.cardinalcoachnc.com/bus-parts.php I needed a shroud for my GM and found it through them. They have ALOT of GM parts buses out back. Shipping probably wouldn't be too bad on just the shroud. Brandon |
Post Number: 2020 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 04, 2011 - 5:46 pm: | |
call Luke |
Post Number: 1247 Registered: 11-2005 Posted From: 173.202.15.164
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 04, 2011 - 6:18 pm: | |
Steven I ran my '54 4104 five years coast to coast numerous times in all kinds of hot weather with no shroud, my main problem was keeping it warm in cool/cold weather. Evidently your shroud was Al!! Unless you lug it on long grades it won't overheat and it is a lot easier to work in that area with no shroud. |
Post Number: 25 Registered: 12-2010 Posted From: 72.156.216.251
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 05, 2011 - 7:42 am: | |
Thanks for the information... It was alum. and I talked to the guy helping me on the engine and he also said that I will have more trouble trying to get it warm in cold weather.. But we dont use the bus in the winter. So I think Im going to run it like it is and see what goes. If I do need one I will call Luke first as he has help me on other things, or I will fab. one up here in shop. Thanks again Steve |
Post Number: 1248 Registered: 11-2005 Posted From: 173.202.16.138
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 05, 2011 - 7:16 pm: | |
Steve, You can make one from Al or steel barn/shed siding or trim, real easy to pop rivet. I made one that way and found out it wasn't necessary, just in the way. |
