genelewis (66.193.8.154)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 12:53 am: | |
Have a fellow busnut who needs some answers and his putter is down. Need to know if anyone out there in 'busnut land' can identify the parts and part numbers needed to convert an 04 and an 06 steering to a Sheppard Unit. P/N for steering boxes and any other required parts. Would I have any luck finding a unit in a big truck salvage yard? Does anyone have any clues as to what trucks to look for? gene |
don (Bottomacher) (216.130.152.51)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 8:03 am: | |
Gene, that information is contained in the book I currently have listed on the Flea Market board. Don |
Claimjumper (208.186.109.136)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 11:29 am: | |
Gene, I bought the complete unit with high pressure pump and resivour from NIMCO in NY. At that time it cost me $450.00, that was 3 years ago and everything bolted on as a direct replacement for my 06, one of the best things I did for the coach, it now tracts straight down the road and is one finger control (I removed the external stops on the axle because the Sheppard box has internal stops and you get a tighter turn)>>>Dan (PS 10 hrs. labor to do the switch and you will need a new drag link) |
J.L.Vickers (209.34.28.164)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 12:43 pm: | |
The address for the Sheppard Co.Is R.H.Sheppard Co.INC. 101 Philadelphia st. Hanover,PA 17331 Steering box for the 4104 is 492SEB4A1 pitman arm # 2585533 Use a Vickers VTM42 gear driven hydraulic pump. Note!The PD-4104 requires the above Sheppard steering box and pitman arm.The other Sheppard units Will not work! JLV |
Frank Allen (205.188.209.8)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 5:41 pm: | |
John, is that power steering pump used on sheppard different than the power assist?? i just changed the releif valve in mine Frank Allen 4106 |
Claimjumper (208.186.109.89)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 6:47 pm: | |
>>>The Sheppard system uses a higher pressure pump...(from Vickers 1200 to Sheppard 1700Lbs.)>>>Dan |
Gene Lewis (Genelewis) (66.193.8.154)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 9:50 pm: | |
Don ---Where is the Flea Market Board and what is the name of the book? gene |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 10:43 pm: | |
http://www.busnut.com/bbs/messages/6/4691.html?1067224256#POST26297 Richard |
Jason Windecker (198.81.26.104)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 26, 2003 - 11:20 pm: | |
I have 3 NEW vickers VTM42 Power steering pumps,If anyone is interested please contact me at Businjay@aol.com Best offer, The tag on the pump says $308.75 Make me an offer i cant refuse Jason |
Gene Lewis (Genelewis) (66.193.8.119)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 31, 2003 - 9:30 pm: | |
Claimjumper --- can U tell me how to get intouch with NIMCO in NY. Thanks in advance. gene |
